Ford eco boost
/ Ford eco boost #21
couple years ago I bought a 2012 f 150 had low miles , have 142.000 on it now just got out of the shop $4000 worht of repairs , timing chains and all the bs that goes with it anyone else had good bad experience with one ?
My last work truck was a Ford F250. I will never own another one. My company bought 6 of them at the same time. All 6 spent more time in the garage than on the road.
From what I heard about the eco boost is there are many issues with them also.
/ Ford eco boost #22
What year?
/ Ford eco boost #23
And what engine? The 6.0 diesel and 6.4 diesels certainly have their documented issues... But the 6.7 Diesel seems to be pretty bullet proof.
/ Ford eco boost #24
I have an 11.
1) Drill weep hole in the intercooler, solves most misfire issues. (free)
2) Run iridium plugs (Ford ones) and change often. Less than $100 CDN to change DIY, solves all other misfire issues.
3) Frequent oil changes, it's cheap (Less than $50 CDN for synthetic oil and filter on sale DIY)
I bought it well used and did timing chains at about 130,000 miles for first time. It was throwing a cam position code and had was building crazy boost which cause huge lag. New chains solved all the issues.
Truck pulls like a diesel at low RPM.
A 4k repair doesn't bother me so much now when a new truck like it is 75-80 k here.
I'll drive it until it rots out.
/ Ford eco boost #25
My 2020 rig has such get up and go, and is so quiet and smooth, i am really impressed. I tend to be hard on the peddle, so i only get 18 mpg. But after driving a slug of a diesel 94 dodge ram, i appreciate the quiet, powerful ford.
/ Ford eco boost #26
I have an 11.
Excellent advice! Except that for newer model trucks - from my research 2016 up - the weep hole in the intercooler is no longer needed as Ford addressed the issue.
But yes - the Ecoboost engines (really, any turbocharged engine) is harder on spark plugs so generally accepted advice is to not wait until Ford's recommended 100,000 mile change interval but do it after about 50,000 - 70,000 miles. Also, the spark plugs on a boosted engine don't like large gaps. I was used to gapping my plugs to somewhere around .050 in my older engines. Owner's manual for my Ecoboost (8 years old) recommends a gap of .030 - .033. When I bought spark plugs for my Ecoboost recently at the local Ford dealer the parts guy looked up the specs for my truck and said the latest recommendation from Ford is to set the gap on new plugs at .028 so that's what I did.
Same with the oil changes. Don't wait for the Ford recommended interval of 10,000 miles! Change at 5,000 or sooner and you'll not have to do cam phasar or timing chain repairs.
Cautionary reminder! When you buy ignition parts like spark plugs/coil packs, buy them from a Ford dealer, local or on line. DO NOT buy them from Amazon or Ebay! Google "counterfeit spark plugs" and you'll see a whole list of people who bought on-line spark plugs from Ebay and ended up with a lot of problems. Turns out there are fake "genuine Motorcraft" spark plugs out there that look authentic and come in what appears to be official Motorcraft packaging. But those spark plugs are made of inferior materials and will cause all sorts of problems in short order. Like the center electrode being made of some kind of pot metal instead of Iridium, and the resistors that every spark plug has in the ceramic portion having wildly differing values. NGK spark plugs has a cautionary story to the same effect and gives several cases where engines were actually destroyed by these counterfeit spark plugs. So...if you see an ad on line for a set of 6 spark plugs for $25 - they are probably counterfeit. Genuine Motorcraft plugs for the Ecoboosts sell for $15 - $18 each!
I bought my first turbo diesel 24 years ago. Having pulled loads with big block V8s for years, it was a revelation to drive a truck with an engine that didn't have to run at 3000+ rpm when going up a steep hill or pulling 20,000 lbs. This little 3.5 Ecoboost is tuned to pull the same way. Lots of torque down low, below 2000 rpm. Transmission doesn't need to shift down when pulling a steep hill. As you say, it pulls like a diesel! One big difference though. Hook my turbodiesel to a heavy trailer and the fuel mileage will drop maybe 4 mpg. Hook my F150 Ecoboost to a trailer and the fuel mileage (21 mpg not towing) drops in half.
/ Ford eco boost #27
Ya, Ford said we could change engine oil at 5 to 10K. We went with the crazy 5. Seems those spark plugs might stay in, if left in the block to long. Maintenance is cheaper than new truck.
/ Ford eco boost #28
Good friend of mine is the mechanic for our towns Police units. They run Ford Explorers and a few F150s.. All have the EB 3.5. He says he drops the oil every 3500 miles and just does basic maintenance on the cars until they hit 125K miles and then they go to auction. He has very few problems with them.. And they are driven hard by people who didn't pay for them or care about them.
/ Ford eco boost #29
I wonder what they changed to solve that issue?
/ Ford eco boost #32
Y'all are lucky so far. I have read that the Ford
ecoboost to treat it like the plague.
Common issues with Ford's EcoBoost engines include: carbon buildup on intake valves due to direct injection, intercooler condensation, timing chain stretching, ignition system failures, coolant leaks, turbocharger problems, and potential issues with cam phasers;
willy
/ Ford eco boost #33
willy
I was terrified of the issues as well and bought a well used one. These are great engines, my experience based on the original ecoboost found in my 2011.
I was going from an older diesel with manual transmission and liked the diesel like torque curve and select shift transmission of the Ecoboost.
Intercooler condensation solved easily by adding a weep hole to the intercooler
Premature timing chain and cam phaser issues are related to oil not being changed often enough and improper oil filter without antidrain valve.
Ignition issues mainly due to improper plug gap and/or incorrect plugs and cheap coils.
I've had no turbo issues other than waste gate seizing up, fixed with PBlaster and using compressed air to work the actuator back and forth.
Only coolant leak was the crappy overflow tank quick connect, I replaced with a kit designed especially for that fitting on the ecoboost. No more leaks.
/ Ford eco boost #34
willy
I agree all those issues happen to the eco boost. I don’t own one but have a 5.0. I know people that own one and my general feeling is they are a solid engine no more likely to be a problem than other engines. They have been improved over the years too. For example they are both indirect and direct injected to prevent the build up on valves.
/ Ford eco boost #35
Before we purchased our 2019 version, it was difficult to find someone who had grief with the more modern versions. Seems ford has got the problems largely fixed. 🤨
/ Ford eco boost #36
ECO-Boost is probably Ford's WORST engines in their entire history. Anyone that got over 100k miles on one is exceptionally lucky or blew a small fortune into keeping it going. More than just my opinion though...there are literally thousands of videos on utube alone on this issue. Here's a "nice" synopsis. Ford EcoBoost Problems: Are Ford EcoBoost Engines Reliable?
Sorry guys that own Fords but I have watched this corp and most other domestics go from ruling in the 60's to dragging ass like they are now. It's all about making money, not a great product. Can anyone say "EV" hell?
/ Ford eco boost #37
It's like Ford Mo Co suddenly forgot how to build 4-stroke engines all of a sudden...https://www.ford-trucks.com/articles/ford-recalls-90k-2-7l-3-0l-ecoboost-powered-models-over-potential-engine-failures/
And now transmissions! Isn't this about EVERY SINGLE 24 model made? https://www.cnn.com/2024/06/25/business/ford-recalling-550000-trucks/index.html
Sorry guys but this company has obviously lost it's way. There are many many more dangerous recalls on Fords right now. I stay FAR away from an F product....never know what's going to blow.
/ Ford eco boost #38
My area in Texas has seen what you say. The Ford dealer in the small town will probably close it doors forever soon.
/ Ford eco boost #40
Don't worry Ram owners (I sold my last one happily after MULTIPLE issues dealer couldn't/wouldn't fix) you are not immune to quality issues...
2001 Peterbilt 378 T/A Wet Kit Sleeper Cab Truck Tractor (A64194)
2001 Peterbilt 378...
2017 Ford F-150 Ext. Cab Pickup Truck (A64556)
2017 Ford F-150...
2019 John Deere 314G Compact Wheel Loader Skid Steer (A64553)
2019 John Deere...
2025 HT360W Mini Walk-Behind Track Loader Skid Steer (A64553)
2025 HT360W Mini...
2018 CATERPILLAR 289D SKID STEER (A65053)
2018 CATERPILLAR...
2003 NOBLE 12000 GALLON WATER TOWER TRAILER (A65054)
2003 NOBLE 12000...
