Kubota B20 bucket "blade"
/ Kubota B20 bucket "blade" #1
johneking
Hot Springs, AR.
Kubota B-20
I saw a "stump/root rake" on here and have a Kubota B20 with a 56" front bucket and am interested in learning more if anyone can help.
As I live in Arkansas and there are over two rocks around here :D and I do move gravel {varying sizes} from time to time, I'd like something that will hold up to that.
Any help is appreciated -- thanks.
Also, if anyone knows of a used bucket {I need to do some serious repairs on mine!} the part number is: 75580-59010.
/ Kubota B20 bucket "blade" #2
I looked and could find nothing about a stump/root rake. Your FEL and bucket is not the best thing to use for digging up stuff. The FEL and hydraulics can, quite easily, be damaged by rooting around.
That said - there are two types of bucket edges that can improve bucket use.
Both can be called tooth bar. One has "fingers" the extend beyond the bucket lip. The other has triangular extensions. Look at "ratchet rake" for an example of this one.
This is my bucket with the fingered extensions.
Thank you for your response -- I'll check this out.
I could swear I saw one on here, but may have been somewhere else.
/ Kubota B20 bucket "blade" #4
Enjoyed our B20. Did use a quick-spade on it and managed to smiley face the bucket. Straightened and reinforced with plates welded underneath.
Highly recommend the Piranha toothbar from BXpanded. Strengthens bucket and improves digging and grubbing on small tractors.
Do like the added benefit of the skidsteer attachment on the current B26.
/ Kubota B20 bucket "blade" #5
Thanks - Smokydog. That's the name I was struggling to remember.
Piranha tooth bar
/ Kubota B20 bucket "blade" #6
That yellow tooth bar in my post more than doubles the strength of the lip of the bucket. The tooth bar came with some clips. I guess for - easy on, easy off.
I drilled completely thru the yellow tooth bar and lip of the bucket. Used grade 8 - one inch diameter bolts for a permanent attachment.
/ Kubota B20 bucket "blade" #7
I picked one up for my T25. It’s been awesome
/ Kubota B20 bucket "blade" #8
FullMetalBucket - that's the creature I speak of. Looks good on your bucket. I've seen a Piranha attack a stand of brush. It did an awesome job.
Somehow or other I want to figure a way to attach a HD Piranha bar to the lower teeth of my Land Pride grapple. Around the close in yard - I use the grapple to grip & rip out stands of Buck brush. A P-bar would help hold what I grip.
/ Kubota B20 bucket "blade" #9
My M59 came with a well worn but strong long bottom, high capacity skidsteer type bucket. Only 60” wide. Cutting edge worn 2” back more at edges than center. Have other buckets but learned to really appreciate added maneuverability and digging performance of a narrow bucket. The higher back guard would be difficult climbing over for a skidsteer egress but not an issue for a tractor.
BXpanded is about 10miles from the farm. Went to them to maybe get a custom weld in Piranha bar. Looked over pictures and measurements and made a custom, wider for bucket wear, piranha toothbar. I welded it in. Beyond my expectations how well this toothbar can clear brush and small trees! Pulling stuff out by the roots with minimal ground disturbance. Digging in hard ground greatly improved too. Far superior to toothed bars or buckets for tractors.
If you can sketch what you need they might be able to help.
/ Kubota B20 bucket "blade" #10
Piranha markets (originally?) to BX owners, so they weren't on my radar for a long time. Last year I ordered a Piranha Tooth Bar for my L4060, and it has been fantastic. I graded a pole barn site, dug out and removed 20 cubic yards of trash concrete, and layed an equivalent amount of gravel. After all that, it barely looks like it was used at all.
Thank you so much for this information -- that is EXACTLY the leading edge I saw before and clicked the link you included and just completed the order.
Looking forward to getting it and putting it to work!
/ Kubota B20 bucket "blade" #12
B20’s are tough as nails little tractors. Our first compact tractor that proven how valuable and versatile they can be. Show off that big toothy grin when you get Piranha bar installed.
/ Kubota B20 bucket "blade" #13
I second this.
Tears out blackberries by the roots as well as many shrubs and smaller trees. I've been reticent with the concept of the "root rake" grapple because of ground disturbance, I already barely have soil in places.
Unfortunately doesn't do much for poison oak, but at least that doesn't fight back like blackberries when you yank it by hand. No, it plays the long game...
Only minor downside I've had with the ptb (piranha tooth bar) is that it doesn't play nice with a clamp-on trailer hitch; I can't get the hitch to be secure enough that it doesn't wobble back and forth and I suspect it would be better without the ptb. However, I can live with that, and I can't live without the ptb. It's by far the most important thing I've bought for the tractor so far, because of the above root pulling and increased digging ability.
Nice thing is unlike the typical tooth bar, back-dragging is barely affected by its presence.
/ Kubota B20 bucket "blade" #14
I was surprised how well it fit my TYM when I know they were originally marketed for Kubotas. Very snug, doesn’t wobble at all, and I put it to the test, back dragging, attacking bushes and small trees, scooping dirt and pea stone etc. Those teeth are pretty sharp too, have to keep mind of them.
/ Kubota B20 bucket "blade" #15
Indeed; my ptb - and the bucket edge it guards - look brand new 7.5 years & 850h on.
/ Kubota B20 bucket "blade" #16
I sent off an email to Piranha today. Asking if they can match up their HD model to the lower teeth of my grapple. Interested to see what they have to say.
/ Kubota B20 bucket "blade" #17
For a couple of years I could not figure what the grated rectangles in the pic below were for. Dealer chuckled - my grapple is very HD -820 pounds of AR400 steel. It's actually designed for a skid steer and the rectangles are steps to get into your skid steer.
