10kW Ground Mounted Solar Panel System
/ 10kW Ground Mounted Solar Panel System #1
Pettrix
High Desert Southwest
I am looking to do a 10kW ground mounted adjustable solar panel system. I am on 15 acres so I have plenty of room for ground panels. I also will want them to be adjustable so I can change them from winter to summer sun angles.
I currently use under 600 kWh of electricity per month. That will go up slightly as it will be servicing another energy efficient house.
I am tied to the grid and will remain that way. I am still on the fence about doing a lithium battery backup system. Costs and possible fire risk with those systems has me apprehensive.
The solar panels will be coming from China (over 80% of the panels are made there). Not sure which type/brand of inverter I want to go with.
Any ideas/input would be appreciated. Anyone else here with ground mounted panels? Did you use concrete form tubes to use as anchoring points for the solar panel rack system?
/ 10kW Ground Mounted Solar Panel System #2
If you don't have net metering, you may also want batteries to time-shift power consumption from your panels. For example the new rules in California pay close to zero for power you send to the grid so the only way that solar pays off is if you also install batteries so you can keep your excess power to use at night.
Supposedly the newer batteries that use Lithium Iron Phosphate are safer than the batteries used in laptops and cars.
If your area has multi day outages in the winter consider a system with a way to use a generator to top off the batteries. Some of those like Enphase require a serious standby generator, some will let you use a portable gas generator.
/ 10kW Ground Mounted Solar Panel System #3
Carefully calculate any extra costs that the adjustable mount(s) may incur over the cost of a basic fixed rack, vs the expected increase in electricity - particularly if the solar is to augment grid power.
This is slightly different, but when I was putting my system in, there was a choice in which microinverters to use; one had a higher capacity which would not "clip" the peak output, but cost a bit more - over the expected life of the entire array the extra cost was unlikely to be paid for by the slight amount clipped by the lower capacity units.
No appreciable fire risk with LiFePO4 batteries and they're a better bet in the long run regardless.
If you can afford ~30-40kWh or more of battery, I doubt you'll regret the purchase; batteries also allow you to make more efficient use of a back-up generator (it can run at higher load = max efficiency when the batteries are low for recharging them, then turn off and let the house run on battery, until it needs recharging again, etc).
/ 10kW Ground Mounted Solar Panel System #4
I have a 6kW 3 array hillside mount with panels now 15 years old.
Twice a year I adjust the angle and it's about a 5 minute job for all 3 arrays.
The mounts were expensive and required additional city inspection for the depth of hole and rebar...
My panels are 160W and now they would be double or more in the same footprint
/ 10kW Ground Mounted Solar Panel System #5
I'm likely to add 5kW to my system in the next few years, and I'm more and more interested in an adjustable mount, so please let us know what your research is finding - even if it's a mount system you've decided not to use. The data and reasons for your decision could be very helpful for me everyone here now and in the future.
/ 10kW Ground Mounted Solar Panel System #7
My panels are 160W and now they would be double or more in the same footprintView attachment 1870533
What size are the 160w panels? I would bet money that you are virtually the same watt per square foot as modern panels. Density hasn't increased by a measurable amount. 320w panels are literally double the size of 160w panels.
/ 10kW Ground Mounted Solar Panel System #8
LD1 turned me onto Sinclair sky-rack 2.0. It is all US made steel, galvanized and 50 KSI. They have options for heavier duty posts and racking depending on wind, snow load, and panel weight. They have screw jacks at each post so the angle can be set wherever it needs to be and they will custom punch the direct mount rails as well which saves money as well. The shipping was the only thing that was a bit pricey - about half of the rack cost but happy with the quality.
Eventually may add more panels and may experiment with a mount like ultrarunners with tracking
Here is LD1's solar is complete thread.
/ 10kW Ground Mounted Solar Panel System #9
I would need to measure and post as it was a long time ago…
/ 10kW Ground Mounted Solar Panel System #10
Desert southwest, This area has the maximum sun hours per day of anywhere in the USA. I wouldn't be to concerned about the need to adjust your array tilt there, because of this.
Lived in AZ with solar and I just used a non-adjustable ground mount, because it was the cheapest way to go.
My solar arrays in Washington State are also non-adjustable ground mounts, not much gain in the winter months here when adjusting tilt.
A 6 panel array in a 65 mph wind could easily have in the range of 1800 lbs of uplift forces. I use an 18" auger on a skid steer for all my installs and drill to 54", and install per the manufacturers written instructions for the spacing of the holes. Prop up the upright sch 40 and pour a 3,000 lb air entrained fiber mix. No rebar in the holes, this meets any engineered specs I have seen.
Just prop the verticals up off the bottom of the hole so they do not have soil contact.
Plugged in a 10 kilowatt system for Casa Grande, AZ. Based on high desert in the southwest.
The attached pdf; output is based on 10 kwatts of panels and is from the pvwatts site at the link here. It is quite accurate. You can play around with the tilt angle for your location to see the difference you would achieve, but I think you will find that it won't make to much difference at your latitude.
  • 10k az pvwatts_monthly.pdf
/ 10kW Ground Mounted Solar Panel System #11
I still use NAZ (Solar Electric), they have great customer support when needed and also will do a free initial consultation (put all the pieces togther that you need for a complete install) that works best for your site and intended use.
They curently are having a 7% off sale. edit: through the 2nd of December
/ 10kW Ground Mounted Solar Panel System #13
Forget the adjustable mounts and just add a panel or two. You will come out $ ahead.
Yep,
He could buy 14KW of panels for what just the adjustable ground mount cost delivered.
I'm looking at 750w bifacial panels. I am able to get them at a good price directly from China. For the Inverter, I am looking to get the EG4 18KPV
/ 10kW Ground Mounted Solar Panel System #15
What is the wind rating on those panels? Will that be enough for where you are? The panels aren't exactly small.
All the best,
Peter
/ 10kW Ground Mounted Solar Panel System #16
Some Bifacial panels have thinner glass, it appears that it is mainly because they are placing glass on both sides of the panel and are trying to reduce the overall weight of the panels (my opinion).
The glass on the back side of the panels is thinner than on the front side and can crack with a minor hit from a tool. Don't ask me how I know this!
If you get hail where you live, I would recommend looking into the hail testing for the panels as they might have thinner glass. There is a UL listing for this, that has a standard test procedure that manufacturers test to.
A 750 watt panel must be almost the size of a sheet of plywood!
EG4 18 is supposedly a good inverter, never seen one though. I only install low frequency inverters for off grid customers.
/ 10kW Ground Mounted Solar Panel System #17
That is the inverter I bought plus two Power Pro batteries (28.6 KWH total) and 32 Bifacial 450 (540) watt panels. If it gives me trouble I will be going to a Schneider or Midnight/ Trace LF inverter.
First full day in the sun but now I need to get the AC wiring Inverter and batteries wired/mounted
Averaging 375 watts so 12000 watts for a few hours today.
Can't wait to get the rest up and running.
ps. Really Happy with the Sinclair Designs season adjustable ground mount, even though it was pricy with the shipping from Michigan.
Boviets are heavy for a 450 watt panel 68 lb each and have tempered glass. They were one of only two Panels PVEL tested with Ice balls that did not break due to impacts.
“Across the past year of hail testing and dozens of modules tested, Boviet Solar’s double glass modules were one out of only a couple module models where neither sample tested experienced breakage in our 50-mm-diameter hail test.
We typically see a greater than 85 percent glass breakage rate for double glass modules in this test. Boviet Solar’s glass backsheet modules also showed impressive results,” said Tristan Erion-Lorico of PVEL".
Funny thing is there is a bit of panel warping on these panels, Guy over on DIY solar said his Pigmy Goats have jumped up on his same model panels and walked around and not damaged them. We will see.
/ 10kW Ground Mounted Solar Panel System #18
ps. Really Happy with the Sinclair Designs season adjustable ground mount.
Looks nice! Thanks for sharing the details.
What is the angle of your array?
All the best, Peter
/ 10kW Ground Mounted Solar Panel System #19
All the best, Peter
I only used an old harbor freight angle level and it is sticking, I ordered a better electronic one but tried to set the angle to 45* in the pictures. December that would be correct for our latitude.
Sinclair Skyrack 2.0 is fully adjustable between 15* and 55* I believe. Pic of minimum angle while tightening bolts last night.
/ 10kW Ground Mounted Solar Panel System #20
The economics of solar varies tremendously from state to state. The big things to look out for are your state's policies on net metering, whether it's allowed and what rate they pay you for power returned to the grid. In some states there are additional incentives like Solar Renewable Energy Credits (SREC's) and even direct subsidies.
There's also a federal tax credit.
40ft High Cube Shipping Container (A65583)
40ft High Cube...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
Frontier RC2072 (A64126)
Frontier RC2072...
2005 Kubota L39 (A64126)
2005 Kubota L39...
John Deer MX8 Bush Hog, 3pt, Dual Gear Box, PTO (A62679)
John Deer MX8 Bush...
2018 MACK CXU (PINNACLE) (A65643)
2018 MACK CXU...
