What did you do with your Power Trac today?
   / What did you do with your Power Trac today? #411
I mounted a quick attach plate to the side of this hydraulic wood splitter (instead of 3 point attachment on the end). It’s great to be able to drive right up to where the wood I’d cut down.
   / What did you do with your Power Trac today? #412
FWIW: I used a splined PTO hydraulic motor from Surplus Central, and a PTO drive coupler that is a heavy duty version of a LoveJoy coupler, which has a 3/4" disc of fiber reinforced rubber bolted with six bolts, three to each shaft. I think that mine is a part of a Landpride dual brush hog (it was cheap).
Lovejoy couplers aren't great with impacts in my experience. A V-belts work pretty well to absorb impact and vibration.
All the best,
Peter
I'll take that under advisement. Thanks! (y)
   / What did you do with your Power Trac today? #413
I thought about converting the log splitter from gas to hydraulic when the original engine started leaking from seals and such, but I need the PT425 to bring the large rounds up to the splitter sometimes. So $99 Harbor freight engine took care of that. Exact replacement.
I do use the spare Q/A plate with receiver ball hitch to move the splitter around the yard, though. Very handy! (y)
   / What did you do with your Power Trac today? #414
This wasn't today, it was a couple summers ago doing the garage addition. There's always been a question on the lifting capacity of the PT425. It lists 800#. Here's a picture of mine with the large bucket and 12 sixty pound bags of concrete, so that's about 720# of material plus the bucket out past the QA plate, so that should settle that, at least in my mind. 😛
Just noticed my water level leaning against the original garage back door. That thing has come in handy so many times. I think I have about 100' of clear tubing. I fill it with water that I add some green food coloring to. I got the slab set to within 1/8" all the way around. Not bad.
Hidratrak 8' Rolling Cultivator (A53317)
Hidratrak 8'...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
2022 John Deere Z930M (A57148)
2022 John Deere...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
2844 (A58376)
2844 (A58376)
KJ 20' Metal Farm Driveway Gate (A53314)
KJ 20' Metal Farm...
