What did you do with your Power Trac today?
   / What did you do with your Power Trac today? #401
Getting colder! Hot tub time.
Getting pad ready with PT loader
PT switch to forks and moving tub into place.
What? Where is the tub?
OH, here we go. Need to get in the tub. Deck project was alot of work. FINALLY, Time to enjoy it!
   / What did you do with your Power Trac today? #402
PT1460 makes for a great car/truck mover.
Have this box truck that I use to store a bunch of stuff in. Needed to move it out of the way for some tree cutting. Box truck is packed with metal tube and is very heavy. Of course, it doesn't run right now.
PT to the rescue. Used a tire over the PT mounting plate and a chain just for safety and the PT pushed the box truck to where I needed it in a controlled, safe way with no damage.
Have a great football weekend everyone!
Good job! The 1460 is a beast
   / What did you do with your Power Trac today? #404
I've done identical with my PT425 and dead vehicles in my driveway! :ROFLMAO:
Another good reason to keep an old tire around.
   / What did you do with your Power Trac today? #406
This wasn't today, it was a couple summers ago doing the garage addition. There's always been a question on the lifting capacity of the PT425. It lists 800#. Here's a picture of mine with the large bucket and 12 sixty pound bags of concrete, so that's about 720# of material plus the bucket out past the QA plate, so that should settle that, at least in my mind. 😛
   / What did you do with your Power Trac today? #407
Yea, I think that the PT estimates are conservative, at least for the 1445. I wonder if they are the maximum load at full turn.
Out yesterday, getting ready for a big storm, and replacing sections of some WWII drainage pipe with some new PVC pipe;
The great thing about PTs is the articulation. Those are 18' and 20' pieces of 6" heavy wall pipe on the forks. That's an 8' gate, followed by a seven foot wide space between the electric fence and the pump house.
Piece of cake, and no schlepping pipe.
In case you are wondering why 300psi PVC high pressure water pipe is being used for drainage, the pipes were part of a truckload size lot from an auction of assorted pipe, for less than the price of a single piece of 2" PVC. If the cows kick it, nothing is going to happen. Total overkill, no question.
The day before, I was catching up on some chipping of branches from fire trimming with the PT. Wow, the new blades make the chipper practically a completely different machine. Everything feeds better, and the thin twigs that used go through without being chipped are nicely chopped now. (The replacement blades are the WoodMax US made blades, and they are so, so, much better than the Chinese originals. The US blades aren't cheap, but are definitely way, way better.)
All the best,
Peter
   / What did you do with your Power Trac today? #408
Last spring I picked up a dead 8hp chipper/shredder/vac/blower at the scrap yard for $20. The engine is dead and not worth repairing. I was thinking of adding a Harbor Freight replacement engine like I did with my log splitter, but I'm leaning more towards a hydraulic motor with lovejoy connector. I'm gonna disassemble it over the winter as time permits and check the bearings and such. I think I'm gonna mount it with the ground level discharge facing forward, and making a plate that can rotate 90 degrees to direct the blower left or right. I'd make it removable for chipping. It will be good for garden debris.
   / What did you do with your Power Trac today? #409
Dug out my canna lilies a couple nights ago. We've got about 40' of fence along the pool where I plant three rows of them staggered every spring. Usually plant a couple hundred. Have to dig them out in fall or they die. Can't be frozen. The strip is about 2' wide that I till every spring. So we cut them down after first frost kill, and I used the large bucket to just scoop them out, back up, and dump them out of the trench. Then I walk down the trench and toss the tubers into the bucket after shaking off the dirts. Only took about 25 minutes. Nice having the machine back and running again.
However!!!! I saw oil all over the right footwell. Grrrr. Investigation revealed one of the small hoses exiting through the front to the FEL area had a loose fitting. Tightened it up and all good except for the oil cleanup. I'll have to go through all the fittings now. First time it over 1000 hours that has happened.
   / What did you do with your Power Trac today? #410
FWIW: I used a splined PTO hydraulic motor from Surplus Central, and a PTO drive coupler that is a heavy duty version of a LoveJoy coupler, which has a 3/4" disc of fiber reinforced rubber bolted with six bolts, three to each shaft. I think that mine is a part of a Landpride dual brush hog (it was cheap).
Lovejoy couplers aren't great with impacts in my experience. A V-belts work pretty well to absorb impact and vibration.
All the best,
Peter
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
2016 Nissan Altima 2.5 Sedan (A59231)
2016 Nissan Altima...
John Deere 4520 (A60462)
John Deere 4520...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
2022 Horizon Trailer (A55973)
2022 Horizon...
2015 CATERPILLAR 930M LOADER (A58214)
2015 CATERPILLAR...
