Ford eco boost
/ Ford eco boost #1
mulitweed
john deere
couple years ago I bought a 2012 f 150 had low miles , have 142.000 on it now just got out of the shop $4000 worht of repairs , timing chains and all the bs that goes with it anyone else had good bad experience with one ?
/ Ford eco boost #2
I had a 2019 3.5 EB.. Only put about 25K on it before trading it in .. But had zero problems. Have a 2023 Raptor now with the 3.5EB and its been fine .. Only has 10K on it. .. What I have learned about the earlier EB motors is that they need cam phasers at about 80K. You need to keep the oil clean otherwise they tend to have turbo issues at about the same milage. Timing chains are about 125K.. They are a solid motor but do require maintenance.
/ Ford eco boost #3
i have a 2020 F150 3.5L ecoboost. love the truck. only has 55K miles, but works flawlessly. luckily its the evolution 2 engine, so no timing belt or turbo issues like the evolution 1 rigs. mine was also built after the issues with the phase sensor recall repairs that affected some units. i just lucked out.
/ Ford eco boost #4
I have a F150-2013-3.5 eco boost and it has run flawlessly.
170,000 miles
original plugs
to date battery/tires/brakes are all that has been done
So smooth I wonder sometimes if it is actually running
/ Ford eco boost
170,000 miles
original plugs
im stuck with this one now 4 awhile , cant win them all , miss my 90's chevys went forever ad cheap to work on
/ Ford eco boost #6
Mulitwe it sounds like you’re fixed up for some trouble free driving now. In other words you know what’s under the hood!
/ Ford eco boost #7
170,000 miles
original plugs
Shouldn't those plugs be changed?
/ Ford eco boost #8
It’s a common issue on the eco boost. I bounce over to the F150 forums on occasion and your problem isn’t unique but might have happened a little early.
I can’t remember when or even what kind of car but I helped someone change plugs once. They were platinum with a lot of miles on them, they looked brand new.
/ Ford eco boost #10
So now there are no more problems with the 3.5 eco-boost?
/ Ford eco boost #13
I have a 2014 3.5 eco boost with about 90k on it. Only problem is the blend door motor on the ac. It clicks several seconds every time I crank it or just open the door.
/ Ford eco boost #14
2016 F150 with the 3.5 Ecoboost. 77,000 miles on it. Problem free...best truck I've ever owned and I'm old. Owned a few trucks in my time.
/ Ford eco boost #15
Ive got a 2015 with the 3.5 gen 1 Ecoboost. Im only at 90K on it so far but its been flawless. Timing chains were one of the biggest issues with the early ones but it was mainly due to premature wear from extended oil change intervals. Direct injected boosted engines are known for oil dilution and in the EB's that means chain wear or "stretch". I send an oil sample to Blackstone every year and my reports have always been good with my 5,000 miles oil changes and Mobil 1 oil. I absolutely love this engine, pulls like a freight train compared to my old V8 F-150.
/ Ford eco boost #16
The Gen 1 3.5's didn't have phaser issues that the Gen 2's did, chains wearing is the main issue with the timing set on the gen 1. Clean oil is a must in any new engine and sadly its the most overlooked since most MFG's are pushing 10K intervals now which is a problem.
/ Ford eco boost #18
I think so but my local garage says if not throwing any codes (stutters) and running so smoothly with gas milage in the 20 1/2 range why spend the money is what he keeps telling me?
he is a local old timer who runs a rural 3 door / 2 lift type of shop. A real dying breed and when he finally retires the shop closes forever is my guess.... nothing fancy but a real down to earth type of local community guy. I tend to trust and follow those who know more than I but like you think I should change the plugs.
Cheers
/ Ford eco boost #19
I'd sorta expect any modem vehicle, regardless of quality, to have no real issues while under 100k miles.
And quality ones to go to 200k quite easily. I always intend to drive a car to 200k. Not impressed with "no issues" while under 100k honestly. That should be the bare minimum for the price tag
/ Ford eco boost #20
Only have 58 000 km (36000 miles) on my 2018 3.5 liter and so far, so good. Happy to see the mileage people are getting out of these newer models and relatively trouble-free. Powertrain warranty is over so now I am doing my own oil changes twice a year for piece of mind. The vehicle is more of a driveway ornament than driven, but I do love it.
Vermeer 604 XL-Series (A62177)
Vermeer 604...
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
KBH Tender (A63688)
KBH Tender (A63688)
For Sale L4479 Snowblower and Subframe
For Sale L4479...
Deutz F3L914 3-Cylinder Air-Cooled Diesel Engine - 54 HP - Pump Takeout (A63689)
Deutz F3L914...
2022 CATERPILLAR 310 EXCAVATOR (A62129)
2022 CATERPILLAR...
