Track king dozer 34020
/ Track king dozer 34020 #1
Mark1991
Track king dozer34020
Hi new to this site and would appreciate any information about the dozer listed in the thread title. I recently got one for free it's a 02 model and and runs good only has 73 hours on it but unfortunately the left track is not operating as it should drive wise or steering wise. I have read that a lot of these Chinese dozers are basically made in the same factories and just sold under different names. I can find next to no information about this dozer. Ant help would really be appreciated. Thank you
/ Track king dozer 34020 #2
They are all currently manufactured by CYI (China Yuchai International). Pre Y2K models were manufactured by Guilin Fuda Machine LTD.
I may be able to help you. What specifically are the symptoms?
Thank you very much. The left track seems to not be under power . Also the brake for the same track is not working. I am also searching for a parts manual that might apply to this machine. Before I start dissembling it. If you can point me in the right direction I would really appreciate it. Any advice would also be appreciated. I'm assuming it has to do with the clutch on that side?
/ Track king dozer 34020 #4
If you will PM me your email address I will send you an operators manual (there is no shop manual available for these machines, but the operators manual includes parts). Do you know what engine you have (make and model number)? It should be on a nameplate on the left side of the engine. Better yet, take a good picture of it and post it here. Does your machine have the standard clutch pedal or the hydraulic shuttle clutch (no clutch pedal)?
/ Track king dozer 34020 #5
The steering clutch and brake have a synchronized linkage that works with a single pedal.
Thank you so much for your help already. You have already answered some questions. I wii get pictures today of any info plates I can find. Yes it has a standard clutch pedal. And a right and left pedal for tracks. Thanks again
Mr Bob here is what I could find
Thank you sir. I really appreciate your help. With what I have been reading I'm assuming the steering clutches are dry clutches. Am I assuming right. Also are any part still available that you know of or am I going down a rabbit hole trying to repair this thing. Thanks again for your help.
/ Track king dozer 34020 #11
Yes, the clutches are dry and integral with the brake drum. They are very much like what you will find in forklift and marine transmissions, though not interchangeable. Most all parts are available online from several domestic sources, including:
Northern Tool used to sell the rebadged Nortrac dozer, and still may have some parts available.
Engine parts are the same as found on some popular wheeled Jinma tractors.
/ Track king dozer 34020 #12
My Nortrac 3500 b is not turning left very fast . I do mean slow. The brake band has been changed. Does anyone know how to tighten it?
/ Track king dozer 34020 #14
To jump into this conversation a little late if you don't mind. I was a Farm Pro dealer for a while till I wised up and sold a couple of these under their name and still own one. What Bob said about the manufacturer is true. It was imported under many names and Northern was the biggest for a while. Circle G has some of the parts currently as I am having difficulty with a stuck steering clutch. You may have a broken axle at worse or a bad clutch. The engine is a Jinma 30hp in most cases which is very good sleeved engine. One problem I had was battery way too far away resulting in hard starting. I moved it to over the engine.
/ Track king dozer 34020 #15
Apologies for the late reply. Yes, the steering clutches and brakes are dry. Lots of parts available through Circle-G Tractor, Northern Tool, and a few others.
/ Track king dozer 34020 #16
You get a operator manual
/ Track king dozer 34020 #17
Hi there, I have the same machine 2007 trak king mine has clutch pedal and i have to step on right brake hard to turn right left is sensitive. Any chance you can send me an operator manual?
/ Track king dozer 34020 #18
  • DH326 Owners Manual.pdf
Kholer Magnum 10 Compressor (A63118)
Kholer Magnum 10...
Stone CP13 Asphalt Roller (A64047)
Stone CP13 Asphalt...
2012 CHEVROLET SILVERADO PICKUP TRUCK (A59910)
2012 CHEVROLET...
Kubota ZG222 (A60462)
2020 International LT625 Sleeper 48" (A62613)
2020 International...
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
