Do you bring your battery inside for the winter?
   / Do you bring your battery inside for the winter? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I usually charge all my batteries with a smart charger late in December and then again in the spring and that's been fine. But I have a 6V "weak" battery in my IH Super C that I'm thinking of bringing into the heated garage for the winter. Maybe others like my old truck and some tractors.
I know it can't hurt but does it help?
   / Do you bring your battery inside for the winter? #2
Yes. Really cold temps (or extreme heat) don’t do a battery any good.
   / Do you bring your battery inside for the winter? #3
I agree with @Hay Dude
Most of the time I removed batteries from equipment for long term winter storage and stored them in a temperature controlled shed above 40 degrees F.
I came to this conclusion from personal experience and classes required by an employer working in an Industrial battery shop where my sole purpose was to charge and maintain batteries.
Some of the learned items was the electrolyte level of lead acid batteries is effected by cold temps. As the battery gets colder the density of the electrolyte increases. As the density increase the available current goes down as well as the fluid level.
Ideally the battery fluid level should be checked at 70 degrees F. due to expansion and contraction of the fluid base on battery temp.
If the fluid level is low before winter, the level will get lower and could possibly expose plates and this could cause premature sulfation.
   / Do you bring your battery inside for the winter? #4
Can you avoid battery deterioration by keeping it connected to a solar charger when not in use during the winter? It's a pain to remove the battery from one of my tractors.
   / Do you bring your battery inside for the winter? #5
Yes, but it would be best to have a temperature compensated charger.
Batteries require a higher charging voltage when cold and a lower charging voltage when hot.
   / Do you bring your battery inside for the winter? #6
Thank you.
   / Do you bring your battery inside for the winter? #7
Nope. All my batteries stay in whatever equipment they were installed in. BUT...every one has one of these battery maintainers connected to it. I went the extra step and installed quick connects to each battery so I don't have to raise a hood or remove a battery cover. Temperature compensated, and also a desulfator. I have at least a dozen of these, been using these for years and never had one fail. Since I've been using them my batteries seem to last forever. My ancient John Deere diesel is notoriously hard to start when the temperature is below 50 degrees yet the last cheap Walmart battery I installed in it lasted 13 years.
   / Do you bring your battery inside for the winter? #8
Yes... I bring mine in if I don't used that vehicle for the winter, and I charge them once in a while. It not only help the battery itself it helps to avoid corrosion by having the battery disconnected
   / Do you bring your battery inside for the winter? #9
There was a time when all batteries were stored in the spare bedroom. That procedure went south when I bought the Odyssey AGM battery for the tractor. This new battery weighs 78 pounds and it's location in the tractor could easily cause a hernia.
Now everything is on a state of the art "trickle charger". Besides I am now down from five to two batteries on chargers.
   / Do you bring your battery inside for the winter? #10
Heat is bad for vehicle batteries.
Cold environments are actually good for longevity. It’s only detrimental if you leave the battery highly discharged in sub freezing temperatures.
If you keep your battery in a decent charged state, there’s nothing wrong with leaving it out in the cold.
SAKAI SV544D SMOOTH DRUM ROLLER (A52709)
SAKAI SV544D...
PREDATOR 3500 W GAS GENERATOR (A58376)
PREDATOR 3500 W...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
1969 VOLKSWAGEN BUG (A59575)
1969 VOLKSWAGEN...
John Deere 60 Tractor (A59814)
John Deere 60...
