For those with block heaters
/ For those with block heaters #121
JRHO2 info
If your John Deere 410J doesn't have glow plugs, it might be because diesel engines use a process called compression ignition to ignite fuel instead. In compression ignition, fuel is injected into the combustion chamber while the air is being compressed.
willy
I can hardly believe that this was posted on these forums.
Perhaps I have missed something in this thread.
/ For those with block heaters #123
1 hours always worked for me for the Case/IH that hates anything below 35F.
/ For those with block heaters #124
It may have been mentioned somewhere earlier. We don't live in a too cold climate. My TC45 has started no matter what temps it's in and I let it warm up much longer. Am I harming it in cold weather in this way?? Know nothing about them.
/ For those with block heaters #125
JRHO2 info
willy
The design of the diesel engine is compression ignition. The fuel ignites from heat produced from compressing the air to high pressure. The cold combustion chamber may not allow the fuel/air to get hot enough to combust. A cold engine will benefit this process if the combustion chamber is heated (glow plugs) or the incoming air charge is heated by an element. Sometimes, hot air from a hair dryer directed into the intake might help to get it started. A block heater getting the engine a bit warmer may help too. A warm engine will normally spin faster when cranking which helps too.
/ For those with block heaters #126
It's really surprising how just a little warmed air into the intake will fire off a stubborn engine, gas or diesel. I have a Kawasaki V Twin on my walk behind mower that gets real testy at 40-50 degrees F, and a few minutes worth a fan heater in front of the intake gets it going with 2 pulls.
/ For those with block heaters #127
… and cold hydro oil only adds to the trouble, for any machine with a direct-drive hydro pump. Especially zero turns, as they’re usually spec’d for hydro oil based on an assumption of warm weather operation. My Deere 757 ZTrak is spec’d to run 15W-40 in the hydro pump, and it is a bear to start in a cold shed after Christmas, when I cycle thru the annual maintenance on all my OPE.
I often end up firing up a jet heater in the shed, to warm it up for 30 minutes before that cold start.
I run ATF in my log splitter, which starts much easier in cold than any single-weight hydro oil. But with a big 20 GPM pump, it’s still not an easy pull, when it gets cold. I actually ended up installing electric start on it.
/ For those with block heaters #129
There is an outlet on the outside. My 2 questions are:
How long do you leave the heater running before you start it?
How well do the digital or mechanical timers work when they get really cold?
I’m in NE British Columbia. Can get bitterly cold here. I use a mechanical timer that plugs into a regular wall outlet. Don’t use a GFCI type outlet, they nuisance trip frequently. When the vehicles haven’t been plugged in I have found that 2 hours is sufficient for the block heater to do its job in temps down to -40. At that temperature you should just stay inside by the wood stove anyway.
/ For those with block heaters #130
/ For those with block heaters #131
Around here, we just call that "Tuesday".
/ For those with block heaters #132
I have a block heater, an oil pan heater, and a hydro sump heater on my 25 series Branson. In winter time I have all 3 plugged in to a pig tail zip tied to my FEL mount and plug it into an outdoor timer. It takes about an hour for it to warm up enough that I can just fire it right off with one glow plug cycle. But I'm also using synthetic oil in both engine and hydro. That makes a huge difference.
I have my timer set to come on at 4am, and it will switch itself off at 10am. I have that large of a timer window set so that I can go out there anytime after 5am, or wait as long as 10am to go out on a weekend morning, and just hit the glow plugs once and just fire it up and go. It doesn't get any "warmer" by keeping it on as long as I do, but it gives me a wider window of start up times. Since I'm using synthetic oil and hydro, I can just get moving pretty much as soon as I start it up, with no additional "warm up time" needed. Just get out there and clear the snow and get on with my day.
/ For those with block heaters #133
I've searched the forum and I've seen multiple answers on the subject of how long one should have the block heater on before starting. I live a few hours south of the Canada border and it can get pretty cold at times and for days at a time. So my question is for those of you with block heaters and in the colder climates, how long do you leave the heater plugged in before you start it? I live a 2 to 3 hours south of the Canada border and it can get pretty cold at times.
Before we moved further north, I'd plug the wife's car into a timer and run the cord underneath the garage door. Can't do that up here as we have plenty of mice to worry about. The timer I have is digital and I'm concerned how well it would work when the device gets really cold outside instead of inside. Is the one you use digital or is it a mechanical one? How do they stand up to getting cold? Not to concerned about it getting wet as I can put it under the tractor hood and will get removed when I unplug it when I go to start.
If it matters, I have a 1990 Ford 1520.
I use a mechanical type timer on my tractor. The type you pull out or push in the plastic tabs to start and stop. It is programmed to turn on for an hour, off for an hour for several hours during the daylight hours when I do my snow blowing. Works great.
/ For those with block heaters #134
Is that -40 Celsius or Fahrenheit?
/ For those with block heaters #136
I've seen ethanol wars, engine oil wars and brand wars. This thread is a new one for me: preheat wars.
Yeah, much conflicting information here, but I've learned a lot.
It's caused me to rethink my current home backup generator project. Instead of using an auto transfer switch, I'm changing to manual start for the diesel engine. The auto transfer switch allows only a 4 minute warmup before adding load. The recommended time in the engine manual is 10 to 20 minutes, depending on temperature. With manual start, I can make the call myself.
I'm still considering a block heater or other method of prewarming. I'm not sure of the best method for the climate here. It rarely gets below zero F, and the genset is located inside a barn. The building isn't heated but it does buffer the outside temp somewhat.
I guess the best approach to preheating depends on where you live, the type of engine your trying to start, it's location, and the type of equipment it powers.
/ For those with block heaters #137
Diesel, is an internal combustion engine in which ignition of the fuel is caused by the elevated temperature of the air in the cylinder due to mechanical compression; thus, the diesel engine is called a compression-ignition engine (CI engine).
This contrasts with engines using spark plug-ignition of the air-fuel mixture, such as a gasoline engine or a gas engine(using a gaseous fuel like natural gas or liquefied petroleum gas).
I know very well how engines work.
He wasn’t saying or even implying gasoline vs diesel engines. Not sure why you felt the need to post this unrelated info, for a question I was asking , him
/ For those with block heaters #139
Just my honest informational reply to the question posed.
No other underlying motive…
/ For those with block heaters #140
My M6040 has no block, tank or lower radiator hose heater. It starts well at -20F without these features.
HOWEVER - I'm retired and have been for quite a spell. I have no reason to be anywhere at any specific time. When it's very cold outside - I find it's much better to just remain inside. Hot cup of coffee or chocolate and JD.
I've experienced MAJOR frustration due to extreme cold weather. Get up @ 1am so I can clear the snow off my mile long gravel driveway and get to work on time. Leave for work @ 5am and fight the uncleared county roads. All the way to work. Then...I'm the ONLY fool who shows up for work. Due to heavy snows and cold weather - work has been cancelled for that day.
I'm retired now, baby. I'll go when I'm damned good and ready.
2017 Chevrolet Equinox SUV (A61574)
2017 Chevrolet...
2024 14ft Pairboat Flat Bottom Mud Boat w/ Mudd Buddy HDR 5000EFI 40HP Mud Motor w a 2026 14 B an... (A61574)
2024 14ft Pairboat...
2025 Rake Mini Excavator Attachment (A61572)
2025 Rake Mini...
UNUSED ATS POWER ATS-GAC40Y 40 GALLON (A64281)
UNUSED ATS POWER...
2011 Freightliner B2 School Bus (A61573)
2011 Freightliner...
2025 Spirit Electric Scooter (A61574)
2025 Spirit...
