New Holland TC35-Glow Plug Light
/ New Holland TC35-Glow Plug Light #1
Ghost River Retrievers
Benton County, MS
New Holland
Last week my TC35 wouldn't start, so I thought I'd check the battery connections first. When taking off the first side, my wrench slipped and hit both terminals ... small spark ... I cleaned the connections and tightened them. I went to try to start it and got nothing ... dead as dead can be ... not even the glow plug light came on. I think this is important ... I had left the key in the "on" position, so the battery arc'd with the key in the "on" position.
I tested the battery and it showed "0.0."
I got a new battery and installed it this morning. The instant that I connected the second cable, the glow plug light came on. When I went to start it, I found that the key was in the "off" position. Nonetheless, I turned the key to "on" and waited for the glow plug light to go off ... it never did. After about 3 - 4 minutes, I went ahead and tried starting the tractor and it cranked up right away. I ran it for a couple minutes and the glow plug light NEVER went off. I turned off the tractor and the glow plug light remained on. I removed the key and the glow plug light remained on.
I removed the positive battery cable so the glow plug light would go off, which it did.
Why is the glow plug light remaining on?
What do I need to check?
Thanks for reading and for any suggestions!!!
/ New Holland TC35-Glow Plug Light #2
/ New Holland TC35-Glow Plug Light #3
Yes, I would be checking the glow plug relay, see attached.
  • Electrical - Starting Circuit.pdf
  • Relay locations.pdf
  • Relay Testing.pdf
/ New Holland TC35-Glow Plug Light #5
My TC had a problem where the glow plug light stayed on. It was the timer relay. The New Holland part is very expensive but you can get a generic relay for much less.
/ New Holland TC35-Glow Plug Light #8
Does anyone know if the glow plugs are supposed to come on every time or only for cold ? My ls once over a certain temp won’t , same as my trucks. My tc45 always comes on every time I hit the key. Wiring has been molested on this unit before I got it.
/ New Holland TC35-Glow Plug Light #11
Mine comes on every time I turn the key, regardless of temp. I just wait for the light to go out and it starts right up.
Yes, same with mine.
(And now that I have replaced the relay, it even goes off when it's supposed to!)
/ New Holland TC35-Glow Plug Light #13
Thank you guys ! Mine had a aftermarket cab added on. Every now and then when I turn the key on the turn signals light up. Thought I got all the wiring cleaned up and sorted but still some minor problems.
/ New Holland TC35-Glow Plug Light #14
Fyi the glow plug light dosnt need to work/cycle for the glow plugs to actualy work. I fixed my system and a few months later the light quit even though the glow plugs still work.
/ New Holland TC35-Glow Plug Light #15
As soon as you turn on the key the glow plug light should be on unless you have a problem
common cents we have a new leader
willy
(296) 1"X6"X6' TONGUE & GROOVE (A62131)
(296) 1"X6"X6'...
TSURUM HSZ3-755 PUMP-1 PHASE INDUCTION PUMP (A62131)
TSURUM HSZ3-755...
CENTRAL PNEUMATIC 21 GALLON ELECT. AIR COMPRESSOR (A62131)
CENTRAL PNEUMATIC...
429133 (A61165)
429133 (A61165)
UNUSED WOLVERINE TF1-66-4000G-66" PALLET FORKS (A62131)
UNUSED WOLVERINE...
Vermeer 604 XL-Series (A62177)
Vermeer 604...
