New Holland TC35-Glow Plug Light
   / New Holland TC35-Glow Plug Light #1
Ghost River Retrievers
Benton County, MS
New Holland
Last week my TC35 wouldn't start, so I thought I'd check the battery connections first. When taking off the first side, my wrench slipped and hit both terminals ... small spark ... I cleaned the connections and tightened them. I went to try to start it and got nothing ... dead as dead can be ... not even the glow plug light came on. I think this is important ... I had left the key in the "on" position, so the battery arc'd with the key in the "on" position.
I tested the battery and it showed "0.0."
I got a new battery and installed it this morning. The instant that I connected the second cable, the glow plug light came on. When I went to start it, I found that the key was in the "off" position. Nonetheless, I turned the key to "on" and waited for the glow plug light to go off ... it never did. After about 3 - 4 minutes, I went ahead and tried starting the tractor and it cranked up right away. I ran it for a couple minutes and the glow plug light NEVER went off. I turned off the tractor and the glow plug light remained on. I removed the key and the glow plug light remained on.
I removed the positive battery cable so the glow plug light would go off, which it did.
Why is the glow plug light remaining on?
What do I need to check?
Thanks for reading and for any suggestions!!!
   / New Holland TC35-Glow Plug Light #2
   / New Holland TC35-Glow Plug Light #3
Yes, I would be checking the glow plug relay, see attached.
  • Electrical - Starting Circuit.pdf
  • Relay locations.pdf
  • Relay Testing.pdf
   / New Holland TC35-Glow Plug Light #5
My TC had a problem where the glow plug light stayed on. It was the timer relay. The New Holland part is very expensive but you can get a generic relay for much less.
   / New Holland TC35-Glow Plug Light #8
Does anyone know if the glow plugs are supposed to come on every time or only for cold ? My ls once over a certain temp won’t , same as my trucks. My tc45 always comes on every time I hit the key. Wiring has been molested on this unit before I got it.
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
2022 Ford F-150 Pickup Truck (A55852)
2022 Ford F-150...
Bobcat T590 (A53317)
2013 International TerraStar Enclosed Service Truck with Liftgate (A53422)
2013 International...
LIMA MAC 60KW GENERATOR (A55745)
LIMA MAC 60KW...
2022 Toro Workman 07921 Electric Utility Cart (A54811)
2022 Toro Workman...
