New Holland TC35-Glow Plug Light
/ New Holland TC35-Glow Plug Light #1
Ghost River Retrievers
Benton County, MS
New Holland
Last week my TC35 wouldn't start, so I thought I'd check the battery connections first. When taking off the first side, my wrench slipped and hit both terminals ... small spark ... I cleaned the connections and tightened them. I went to try to start it and got nothing ... dead as dead can be ... not even the glow plug light came on. I think this is important ... I had left the key in the "on" position, so the battery arc'd with the key in the "on" position.
I tested the battery and it showed "0.0."
I got a new battery and installed it this morning. The instant that I connected the second cable, the glow plug light came on. When I went to start it, I found that the key was in the "off" position. Nonetheless, I turned the key to "on" and waited for the glow plug light to go off ... it never did. After about 3 - 4 minutes, I went ahead and tried starting the tractor and it cranked up right away. I ran it for a couple minutes and the glow plug light NEVER went off. I turned off the tractor and the glow plug light remained on. I removed the key and the glow plug light remained on.
I removed the positive battery cable so the glow plug light would go off, which it did.
Why is the glow plug light remaining on?
What do I need to check?
Thanks for reading and for any suggestions!!!
/ New Holland TC35-Glow Plug Light #2
/ New Holland TC35-Glow Plug Light #3
Yes, I would be checking the glow plug relay, see attached.
  • Electrical - Starting Circuit.pdf
  • Relay locations.pdf
  • Relay Testing.pdf
/ New Holland TC35-Glow Plug Light #5
My TC had a problem where the glow plug light stayed on. It was the timer relay. The New Holland part is very expensive but you can get a generic relay for much less.
/ New Holland TC35-Glow Plug Light #8
Does anyone know if the glow plugs are supposed to come on every time or only for cold ? My ls once over a certain temp won’t , same as my trucks. My tc45 always comes on every time I hit the key. Wiring has been molested on this unit before I got it.
/ New Holland TC35-Glow Plug Light #11
Mine comes on every time I turn the key, regardless of temp. I just wait for the light to go out and it starts right up.
Yes, same with mine.
(And now that I have replaced the relay, it even goes off when it's supposed to!)
/ New Holland TC35-Glow Plug Light #13
Thank you guys ! Mine had a aftermarket cab added on. Every now and then when I turn the key on the turn signals light up. Thought I got all the wiring cleaned up and sorted but still some minor problems.
/ New Holland TC35-Glow Plug Light #14
Fyi the glow plug light dosnt need to work/cycle for the glow plugs to actualy work. I fixed my system and a few months later the light quit even though the glow plugs still work.
/ New Holland TC35-Glow Plug Light #15
As soon as you turn on the key the glow plug light should be on unless you have a problem
common cents we have a new leader
willy
2021 Ditch Witch SK800 Mini Skid Steer (A61166)
2021 Ditch Witch...
2014 Ram 1500 Crew Cab Pickup Truck (A61568)
2014 Ram 1500 Crew...
2012 John Deere 1990 Planter (A63109)
2012 John Deere...
New/Unused Landhonor Electric Hoist (A61166)
New/Unused...
UNUSED WOLVERINE QC1-26-20G UNIVERSAL HITCH (A62131)
UNUSED WOLVERINE...
2016 CATERPILLAR 299D2 SKID STEER (A62129)
2016 CATERPILLAR...
