New Holland TC35-Glow Plug Light
   / New Holland TC35-Glow Plug Light #1
Ghost River Retrievers
Benton County, MS
New Holland
Last week my TC35 wouldn't start, so I thought I'd check the battery connections first. When taking off the first side, my wrench slipped and hit both terminals ... small spark ... I cleaned the connections and tightened them. I went to try to start it and got nothing ... dead as dead can be ... not even the glow plug light came on. I think this is important ... I had left the key in the "on" position, so the battery arc'd with the key in the "on" position.
I tested the battery and it showed "0.0."
I got a new battery and installed it this morning. The instant that I connected the second cable, the glow plug light came on. When I went to start it, I found that the key was in the "off" position. Nonetheless, I turned the key to "on" and waited for the glow plug light to go off ... it never did. After about 3 - 4 minutes, I went ahead and tried starting the tractor and it cranked up right away. I ran it for a couple minutes and the glow plug light NEVER went off. I turned off the tractor and the glow plug light remained on. I removed the key and the glow plug light remained on.
I removed the positive battery cable so the glow plug light would go off, which it did.
Why is the glow plug light remaining on?
What do I need to check?
Thanks for reading and for any suggestions!!!
   / New Holland TC35-Glow Plug Light #2
   / New Holland TC35-Glow Plug Light #3
Yes, I would be checking the glow plug relay, see attached.
  • Electrical - Starting Circuit.pdf
  • Relay locations.pdf
  • Relay Testing.pdf
   / New Holland TC35-Glow Plug Light #5
My TC had a problem where the glow plug light stayed on. It was the timer relay. The New Holland part is very expensive but you can get a generic relay for much less.
   / New Holland TC35-Glow Plug Light #8
Does anyone know if the glow plugs are supposed to come on every time or only for cold ? My ls once over a certain temp won’t , same as my trucks. My tc45 always comes on every time I hit the key. Wiring has been molested on this unit before I got it.
2004 MCI D4500 Passenger Bus, VIN # 1M8PDMPA54P056247 (A51572)
2004 MCI D4500...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
Flat Bottom Boat w/ Trailer (A51573)
Flat Bottom Boat...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A51248)
UNUSED RAYTREE...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
Aluminum Boat and Trailer (A51573)
Aluminum Boat and...
