Homemade log splitter. Anybody made one?
   / Homemade log splitter. Anybody made one? #21
Interesting. Your hydraulic cylinder looks much longer than 1/2 the I-beam length. How do you prevent the wedge from inadvertently driving into the end plate?
On your latest setup, are your solar panels connected to 3 phase inverters, or are you using single phase to a VFD at the spitter?
The cylinder is indeed longer than the beam. The story behind that is that originally had a smaller, shorter and used cylinder, then a friend came by and he said he could get me a brand new bigger cylinder for very very good price. So I went with it instead.
With the wedge pushing against the end plate, I still have about 4" left of travel on the cylinder, if I recall correctly. My end plate is made out of two small I beam sections and I left about a 1/4" gap between them, so the axle just fits in there and doesn't damage the edge. There isn't really any risk of push and forcing it against the end plate and it also helps cutting those annoying strings that some types of wood leave.
As for the solar, here in Europe, we have 3 phase 400v pretty much anywhere, so the house is already set up for 3 phase. This is a 4kw solar system connected to a 3 phase 4kw grid tied inverter.
   / Homemade log splitter. Anybody made one? #22
Yep, even the cabin in Austria where I stay has 3 phase at 400 which makes continuous flow electric water heaters viable...
   / Homemade log splitter. Anybody made one? #23
I see some units have a stationary splitter and some have a stationary block or stop. Is there an advantage either way?
As others have noted, the horizontal/vertical splitters are always stationary block. The end away from the cylinder sits on the ground when spitting vertically. If that end were the wedge, you'd be pushing the split pieces into the ground (or trying to lift your splitter off the ground).
A stationary block means the pieces stay right where they are when split (assuming you have a cradle or table to catch them), so they are right there if you need to resplit them or within easy reach if you are tossing the pieces somewhere after splitting. This advantage alone is enough for some people to choose a stationary block, even if they are never using a horizontal/vertical splitter in vertical mode. The downside is that if you are not tossing each piece, the split pieces rapidly fill up the area where you are standing and also surround the splitter making it harder to move if you want to relocate before clearing the pile. The falling pieces can also be a hazard to toes, the engine, or other parts depending on where those parts are located on the splitter. (A well designed splitter of the stationary block type will locate sensitive/expensive parts elsewhere or shield them.)
A stationary wedge pushes the split pieces off the end of the splitter, or onto an exit table if the splitter has one (highly recommended). The downside is that pieces which need to be resplit have to be pulled back to the splitting area (or picked up off the ground, if you do not have an exit table). The upsides are that the splitter pushes split pieces out of the way - even with an exit table, you can use the next log being split to push the previously split pieces off the end of the table. This puts the pile and the falling pieces off the end of the splitter and more out of the way. When the pile grows to where that area is full, it's usually possible to just push the splitter back a few feet, creating more space for the splits to drop. A stationary wedge lends itself more easily to do using a 4-way wedge, particularly one which is easily removeable. People do have 4 way wedges on moving wedge/stationary block splitters, but they are more rare. Some of this is that designing a 4 way to fit the moving wedge is a bit tougher. Another factor is that 4 way wedges are more likely to put a significant side load on the wedge, especially with unevenly cut or gnarly logs. Designing for handle that side load is a lot easier with a stationary wedge.
The high-end splitters with a stationary wedge offer an option for an adjustable height for where the center of the 4-way sits, allowing it to adjust for different diameter logs. (usually hydraulic, though I have seen one set up to operate from a foot pedal and mechanical linkage).
______________
My splitter is the stationary wedge design. I had a horizontal/vertical splitter, but found that I hated using it in vertical mode. I ran horizontal all the time. It was a little light-duty for my needs, so I shopped for a used horizontal splitter that had a working height just a bit below waist high, and had a hydraulic log lifter. Mine does not have the adjustable wedge height option, but since the 4-way is easily removable, I had a custom 4-way made with the cross wedge was at a different height. It turns out I use my custom one more, since I like the smaller split size it offers. I rarely use the one hat came with the splitter.
I've also used my splitter to push pieces right off the exit table and into the back of a trailer, saving some handling. (I do have to go back and shuffle some pieces to get the trailer really full, but the walls of my trailer are not all that tall, so I've only got to do that a couple times per trailer load till it's full, and it's easier than picking them up off the ground.) If I'm lucky, I can get the trailer about half full before I have to do that shuffling. I've seen videos of a guy who split a plastic culvert in half lengthwise, creating a trough which he would prop up on the back of his pickup with the far end up in the air near the middle of the bed. He could push logs up his "poor man's conveyor" and do a pretty god job of loading his truck.
I've discovered that I much prefer the ability to push the pieces off the end of the splitter, even if it does mean pulling back the resplits. The way my table is set up, that pull back is not difficult (though I have seen splitters with exit and work tables that are even better). Since I have an abundance of logs generated from my wildlife habitat and timber stand improvement work on my property, I'll often pick logs which fit the sweet spot of one of my 4 way wedges, and just run them through once and done. You also develop techniques to improve the work flow with various sized logs (as I'm sure people do with any splitter).
   / Homemade log splitter. Anybody made one? #24
I burned wood for 25 years and had to put up 12 -15 cord per year for my outdoor boiler. I had a vertical splitter for a month and found it to be way too much back breaking work picking up all the 20" 10x10 sized oak logs. Then I got a horizontal with stationary wedge and added a 3' square foldable table over the tongue. When split, all the pieces were right there ready to stack. The best thing I ever did with it was I built a hydraulic lift arm. I could roll large pieces of oak rounds onto the lift and it would easily lift them up to be split. I never had one it couldn't lift.
   / Homemade log splitter. Anybody made one? #25
Mine just stands straight up vertically. I back tractor into the pile, i sit on a log and just feed wood into splitter. I toss the split pieces into another pile. When the splitting pile gets exhausted, i move tractor. This also leaves an open area to throw new split pieces. I dont lift anything, just roll them into wedge.
   / Homemade log splitter. Anybody made one? #26
I am planning to build a splitter with a copy of a vertical splitter that can be dropped down to make it more stable. I prefer vertical because you can raise the 3pt hitch and work at a comfortable height.
the one problem I'm having is how to convert my prince valve to spring to the work port instead of neutral so that I don't have to lift the handle up to raise the wedge. I will have a mechanical linkage on the wedge that pushes down on the valve handle to stop the movement at an adjustable height. it currently has a detent to the work port and a pressure release when it gets to the end of the stroke.
   / Homemade log splitter. Anybody made one? #27
I made mine out of all sorts of scrap / surplus metal i've had collected over the years. couple pieces of short 4" wide flange beams left over fro making low- headroom headers, the triangle from a dismantled 3PH grader blade, 2" square tube crosspiece from making a trailer axle, and a hacked up 4-way slip on wedge, and lots of other random leftover pieces that fill 5-gallon pails around here. it used to have a one piece top link, when i built it in 2006, but I converted it to the current strap style pieces so it was quick hitch compatible.
Tractors have single stage pumps, while stand-alone splitters use 2 stage, so no-load applications like retract and taking up empty space on the beam is slower on a tractor. To compensate for this i sized down to a 3-1/2" cylinder, with 18" of stroke so I don't have to move as much fluid. I burn 16" wood, so 24" stroke is a waste of take-up time in both directions. I've had large hardwood on there with nearly no issues - some so big i had to lower it to the ground and roll the rounds on. only time i had any issues is splitting directly into a big knot. that was mainly due to the blunt nature of the slip-on wedge i used. I added a 1/4x1/2 flat bar to the nose of the wedge and sharpened it to a knife edge and that solved most every cut.
never a regret on the smaller cylinder and stroke since i built it.
   / Homemade log splitter. Anybody made one? #29
built this one 14 years ago. pto driven still use it but on a bx 2340 now
   / Homemade log splitter. Anybody made one? #30
nice compact design, i like the bars to pop the wood off the wedge as it goes back up. that bottom plate looks kind of thin. I'm assuming there is a tube frame bar aligned with the wedge to help support the force of the splitter bending the plate.
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
Deere 310L (A53317)
Deere 310L (A53317)
