BleedingOrange
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 2,832
- Tractor
- Kubota BX 2370
Yup, when I am working on different projects, I wake up during the night, and re-think and re-build this stuff until I fall asleep again.
I'm pretty good at double checking things. That's one good thing about going slowly on projects like this, it gives me time to go over not just my written checklist, but also my mental checklist. A few times, I have caught myself and gone back and corrected something.Don’t forget to double check everything. Treat it like a pilots check list. I did engine work on a 70 Challenger, I double checked everything twice except adding coolant and water to the radiator. I caught it in time but just barely.
I have had the same experience, lying in bed and rethinking what I did that day, and getting up to make a note to check it the next day. Most times, I had done it correctly, but did catch myself a couple of times.Yup, when I am working on different projects, I wake up during the night, and re-think and re-build this stuff until I fall asleep again.
Thanks for the correction! It’s been many years since I had that engine built!That's a good looking FAST Mustang you had there.
FYI, a 4" X 4" V8 is a 402 cu.in.
You have to go to 4.125" bore to get 427 cubes.
My 434 is just a 0.030" over 427.
Pulled all the paper off the block today, it looks pretty good, really orange.
Spent about an hour chasing out all the threaded holes in the block, and there are a lot of them. Blew them all out with the air nozzle, the head bolt holes on the Dart block are blind instead of open into the water jacket like the stock block.
Unpacked the new main bearings and made a small modification to the rear main shells to get more oil the the thrust surfaces, a mod I've seen a few SBC builders recommend. Installed the rear seal half in the block and the rest of the upper bearing shells. Got the crank, wiped and blew it off, lubed the bearings and journals and dropped it in place. Installed the lower shells in the caps, lubed them and dropped them into place. Seated them in the block, installed the cap bolts, snugged them up, forced the crank forward and aft to set the rear cap and thrust bearing properly. Dial indicator show .005" end play, which is in spec. Torqued the 7/16" main bolts to 65 ft.lbs. and the splayed 3/8" bolts to 35 ft.lbs., as per the block specs. The crank even spins nice and freely, which is good!
Not sure I'll have time to work in it tomorrow, going to visit some friends from out of town and need to get the BX out and mulch up all the leaves that have fallen. Most of the trees are pretty bare, except for the oaks, they always hang on to their leaves all winter.
View attachment 1734356View attachment 1734357
I have been working on cars since I had my first car, a 59 Buick, that I converted from a 2 barrel carb to a four barrel and installed dual exhaust with Cherry Bomb mufflers.Thanks for the correction! It’s been many years since I had that engine built!
Where did you get the knowledge to build your own engines?
Have fun with the build, I can tell you really enjoy doing it!![]()
Like they say “ if you want it done right then do it yourself “I have been working on cars since I had my first car, a 59 Buick, that I converted from a 2 barrel carb to a four barrel and installed dual exhaust with Cherry Bomb mufflers.
Then, working in the family construction company operating and working on construction equipment and later in trucks and trailers. I've rebuild dozens of Detroit Diesels, Cummins and CAT engines, in addition to lots of Ford, Dodge and Chevy car and truck engines. Until recently I still had service and overhaul manuals for a lot of them, but I sold them as I had no use for them.
I also have rebuilt two Continental aircraft engines, the O-300D in my Cessna 172D and the IO-520BB in my Beech Debonair.
Oh, I also rebuilt the Yanmar 3TA-72 diesel engine that I installed on the genset I built, and a couple of Honda engines off other generators.
So, I have a nearly 60 span of working on engines and mechanical things in general, and understand the importance of procedures and specifications in the repair of things.
Sometimes, I'm sorry I know so much, but I also don't trust many others to do things correctly and not rip me off.
And then if it goes titsup, you know who to blame.Like they say “ if you want it done right then do it yourself “![]()
UH-OHMy wife & I took auto mechanics at a local community college in the 70s. One student rebuilt his motor and it ran but oil smoked. "I don't understand" he said, "I had all the piston ring gaps lined up".![]()
