DutchInNZ
- Joined
- Oct 31, 2020
- Messages
- 98
- Tractor
- Zetor 5745
Guess not; liners are thick steel, structurally stronger than e.g. the top of an aluminium piston. The weakest point is the soft, pliable material of the head gasket and in many places that covers just a few millimetres of separation between the cylinder and one of the coolant channels. I suppose that the hammering of repeated starting with a small enough hydrolock (engine oil leaking along the piston?) could make just enough of a leak there to get rid of the blocking liquid but then of course the coolant is sucked in later on.I wonder if a cyl liner could crack with a hydro-lock?
After 45 minutes running, I doubt that the machine would still blow smoke if it were caused by some diesel from some place. How would that much diesel get there from out of the tank, anyway?
sd455dan is right: check the coolant level and bubbling in the radiator; that is the best indication.
