Sort of related but the hydrolock thing caught my attention…couple weeks ago when the outer bands of Helene dumped some serious water on us, I had our Power Trac (Kohler 25hp gas) sitting out but had a tarp over the engine and the hood down to keep it secure. When I was finally able to get to it, tried to start and it would just “bump” like low battery. Tried charging the battery (it was fairly new) and no difference. Getting my hands in to try and turn it over by hand it would move so far then “bind” up. With the troubles I have had recently I thought I’d take the head off the previously troubled side and investigate for bent rod etc. Upon starting to lift the head, some water started exiting. Getting it off, I found a good bit of water sitting on top of the piston. Never having experienced hydrolock before I thought I’d now seen it. No bent pushrods. Cleaned out both heads, then hand cranked it a few turns. Pulled carb as well and found water inside it! Back together, removed plugs, cranked and blew some residential water out. Running fine now. Would not have imagined water getting into it but those storm rains were heavy and at times blowing sideways…
