How hard is it to learn to use a rental mini-excavator?
   / How hard is it to learn to use a rental mini-excavator? #71
OP posted that on Jan 22.... 6 weeks later and no update from them, eh. So maybe people join here to ask one question and then never follow up (edit: he said long time member, but only has 3 posts). Meanwhile, the TBN forum regulars just keep hashing it out for weeks, lol.
In case it helps at all. I've rented a Bobcat E35 three times now, for whenever I had trenching or land clearing projects. It was incredibly easy to learn to operate. At first you'll be clumsy and slow, but after 10+ hours, it's like the machine is an extension of your body. I went from lurching around with it, to literally bending over trees, grabbing the trunk with the hyrdaulic thumb, rip the rootball out of the ground, spin the machine as you lift up the boom and THROW the tree to the side, drive forward and repeat. I'm talking 4-5" saplings that would take under 20 seconds apiece to pull and discard of. So fun, haha.
After a full weekend of constant digging on slopes (20+ machine hours) I had some serious vertigo!
I would have encouraged the OP to leave the 12" trees intact, and fell them by digging out the rootball and using the tree's weight to pull it's own stump out. Digging a flush cut stump is much harder, you have no leverage. But when you get into a 24" tree.... that might be 80+ feet tall.... thats pretty sketchy to do with a mini ex. Grind those ones instead.
   / How hard is it to learn to use a rental mini-excavator? #72
Here In the South of France I have 7 hectares, 550 olive trees and a lot of woodland most of it not managed before we bought the place 11 years ago. The first digger I had was a JCB 8014, after 4 years I traded it in and bought a JCB 8025. This machine is much more powerful. We have a lot of areas of rocky ground and with the grab bucket I can dig out and move some very heavy stuff. I also use the machine for felling trees, with the roots and all, then hold the trunk up level to be able to chain saw into logs without having to bend over. Handy at my age – 78.
I would say most people with reasonable hand/eye coordination can learn to dig holes, basic trenches, push over trees etc but it needs care. Its easy to injure the machine itself, for example by over curling the bucket and hitting the boom.
I was a pilot (private) for 40 years and operating the digger gives me a satisfying way of keeping hand eye and feet coordination - except that the pedals operate in the opposite sense than on an aircraft.
Greater skill is required for fine finishing and smoothing and that is unlikely to be developed over a couple of days hire.
Our land is on an slope so one safety tip is always to wear the safety belt. Not so much in case you turn the machine over but more to stop you going head first out the front door if stopping suddenly especially going downhill.
   / How hard is it to learn to use a rental mini-excavator? #73
My brother borrowed ours for the first time a couple years back. Drainage issue that the city wouldn't take care of....so he did it himself.
Now this guy is total city. He tries to act like he's country but he was happy with his EV car vs a deer stand.
I showed him the controls when I dropped it off at his house. Surprisingly, he took to it rather quick. In no time he was moving and leveling dirt and digging trenchs.
He still got in trouble with the city cuz of doing the work but he told them to pound sand
   / How hard is it to learn to use a rental mini-excavator? #74
If you can handle a tractor with a front end loader you can figure out a mini excavator pretty easily. The 2 handle machines are simple operate and easy to adjust to. Just take your time and know you will make some small mistakes.
   / How hard is it to learn to use a rental mini-excavator? #75
I know the OP has gone radio silence on this post, but for anyone else considering an excavator, the best advice I got was move so slow that it seems you are not moving. You will speed up slowly but you will learn. That is true.
My second point is a safety warning. The machines are usually set up so you cant bash yourself with the bucket. But you can still kill yourself with the material you are moving.
I was pulling some pushed down trees that I had cut root balls off of. There were a few stacked together. As I reached out to pull some forward, I didnt notice that one of them was about 5 feet closer than I thought and I pulled it right thru the glass and stopped with the end of the log about a foot from my chest. It happened so quickly that I could easily have pushed the log right thru my chest. I only stopped by chance. I hadn’t even processed what happened, to know that there was a problem.
Be careful.
   / How hard is it to learn to use a rental mini-excavator? #76
1) Watch some excavator fail videos on YouTube so you know what not to do.
2) Make sure you learn in excavator control pattern and not backhoe so you don’t feel inferior for the rest of your days;)
   / How hard is it to learn to use a rental mini-excavator? #77
Our land is on a slope so one safety tip is always to wear the safety belt. Not so much in case you turn the machine over but more to stop you going head first out the front door if stopping suddenly especially going downhill.
Good post. Even with 150 hours in the seat I’m still not great at finish grading with my grading bucket (no teeth.)
2020 DRAGON ESP...
2006 CATERPILLAR 420E BACKHOE (A59823)
2006 CATERPILLAR...
Alamo SHD96 Flail Mower
Alamo SHD96 Flail...
2018 Ford Escape 4WD SUV (A59231)
2018 Ford Escape...
2017 Case CX145D (A60462)
2017 Case CX145D...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
