Digging Post holes
/ Digging Post holes #1
Threerots
John Deere 5400
Hey guys,
I need to dig a hole for a 12 foot by 8-9 inch pole. I have a 9 inch and a 12 inch auger. The ground is concrete hard and possibly within the root radius of a large tree. My question is would it be easier to drill an initial hole with the smaller auger (like a pilot hole) and then enlarge it with the larger auger or just start out with the larger auger.
Thanks
K
/ Digging Post holes #3
Just start with the 12'' if that's what you need if you do a 9'' first then go the 12'' the bit won't stay center it will slip to one side.
/ Digging Post holes #5
I have done many holes in hard dry clay, I needed to climb on the post auger for it to dig, in the future I will weld a vertical shaft on the post auger in order to insert weights to it instead of my body weight. I know rocks are a pain when you hit them good thing I don't have very many. I imagine large roots could be a problem I am guessing you will have to cross that once you get there.
/ Digging Post holes #6
I got a power down assist on my speeco post hole driller that helps alot. As i recall it adds 250# of down force.
/ Digging Post holes #7
Hey guys,
Thanks
K
I would use the 12." Don't know your soil, area, and schedule, but waiting for rain is always better. If you have to dig now, I would take your sharpened digger bar and chip off the top layer of sod and hardened soil, to help the auger "bite."
Second, sharpen your auger advance knives as much as possible, and often, when digging.
If this is a big tree, any larger root is going to stop you and shear bolts/pins. You will have to take a chainsaw or something else and manually clear the root ahead of the auger. So, if possible don't get into that fight. Identify your root "leaders" going out from the tree base and dig in between them.
If it's not solid clay, you can fill the hole with water overnight to soften the soil since you're only doing one hole.
Last, buy some extra shear bolts/pins and don't use anything harder than recommended by the manufacturer. Pull your digger up often to clear it to keep from "screwing" it into the hard ground and breaking yet another shear bolt...
I personally would not ever stand on the digger frame to add weight - could be your worst day ever...
Good Luck.
/ Digging Post holes #9
I find that the best time to dig post holes is right after snow melts and ground thaws. Way way way easier than later in summer
Definitely better digging with moist soil! But watch out if you have clay type soil and don't raise your auger frequently to clear the hole, you can screw your auger into the ground and not be able to raise it up! Been there and done that, plus there is no reverse for the auger unless you have a hydraulic unit! Then you have to disconnect the auger and manually unscrew it out of the ground. Not and easy task and may need a large pipe wrench for leverage. Same thing can happen with roots if the leading edge slips under a root in soft soil, it just pulls the auger into the ground like a screw into wood.
/ Digging Post holes #10
I have a hydraulic auger on the FEL with down pressure and reverse, so can't comment on 3-point tactics. But, I'd go with as large as possible at first, your 12" or borrow a 15". The holes don't necessarily go straight in roots and rocks, so wider can help.
/ Digging Post holes #11
I'm dealing with super hard ground right now while building my fence. It's off how I can drill all the way down in one area, but barely scratch the surface just a little ways away. I have a six inch and 12 inch auger. I'm just using the 12 inch.
If I can't get it to drill, and the ground is to hard to even scratch the surface, I use my SDS Max Hammer Drill with a shovel bit to dig a hole as deep as I can. Then I fill up the hole with water.
Usually I can drill the hole all the way down the next day. But sometimes I can't, so I add more water. This might last all week, with me adding water, then coming home from work, getting on the tractor to see if it will work. If it doesn't, I fill up the hole with water and try again the next day. Rarely does it take more then three tries to get the hole drilled.
I also play around with the speed of the auger. Usually it drills best for me at about 1,100 RPM, but sometimes if it's not working, I'll raise and lower the auger a few times to see if I can change something, and then speed up the auger to 1,500 RPM's. This rarely works, but every now and then, it does work!!!
I've bought three different brands of 3 point augers. The Country Line from Tractor Supply is the best that I've found so far. It can be tricky finding new teeth for it from Tractor Supply, but Amazon always seems to have them.
/ Digging Post holes #12
Cant you just wait until spring? Or does that even make any difference. For me, i dont bother trying to dig a hole late in summer.
/ Digging Post holes #13
Spring is super easy to drill holes. Same with pounding T-Posts and taking out trees. But it needs to get done as soon as possible, and dealing with hard soil just means a few extra days of filling the holes with water as I work my way down.
Land Pride Auger (A61166)
Land Pride Auger...
2009 Chevrolet Silverado 2500 Crew Cab Pickup Truck (A61568)
2009 Chevrolet...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59909)
2018 FREIGHTLINER...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
2014 Sea Ray 250SLX Bowrider Boat with T/A Boat Trailer (A61569)
2014 Sea Ray...
New/Unused Wolverine 72in Quick Attach Tiller (A61166)
New/Unused...
