Putting Accumulator on Farmall 110c 3 point hitch. Need to know where the correct port it.
   / Putting Accumulator on Farmall 110c 3 point hitch. Need to know where the correct port it.
Update: Years to get the answer I wanted and finally found a tech that knew right where it was. Put the accumulator on and it was awesome. So what do I do? I trade the tractor the next day. :) Got offered a great price on a Kubota m6-111 that I could not refuse. Now to find the test port on that one.
If anyone is looking into doing an accumulator on a Case tractor I ran 900 pounds of nitrogen in it. Blower hangs back a ways and weight in at 1900 pounds. Made a huge difference in ride.
   / Putting Accumulator on Farmall 110c 3 point hitch. Need to know where the correct port it. #12
At least the Kubota has external cylinders, so it should be easier to figure out.
I run an accumulator on the loader and can only recommend it. Definitely a game changer in how the tractor rides.
   / Putting Accumulator on Farmall 110c 3 point hitch. Need to know where the correct port it. #13
Yes a total game changer in the ride quality. And I don't even road my tractor very much but my trails in the woods are nice enough to drive fairly fast but are not perfectly smooth so it makes the Mod worth it for me. My cylinders were external so it was easier to T into the hose. I have a manual valve on my loader accumulator and 3pt hitch but I really would have liked to have a switch in the cab but so far I haven't felt the need to switch them off.
   / Putting Accumulator on Farmall 110c 3 point hitch. Need to know where the correct port it. #14
Something like this would make it easier to turn On or Off from the cab. You would have to choose if you want to normally closed or normally open.
I only turn mine off for the loader when I'm scooping dirt. Otherwise it tends to dig further than I want it to. But moving the full bucket with the accumulator there is such a breeze and should also take a lot of the shock load from the hub bearings.
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A56438)
2022 Schulte...
2010 Honda Accord Sedan (A59231)
2010 Honda Accord...
Bad Boy Renegade Diesel Zero Turn Mower (A59814)
Bad Boy Renegade...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A56438)
2002 Chevrolet...
Westendorf TA-29 Loader (A59814)
Westendorf TA-29...
