Putting Accumulator on Farmall 110c 3 point hitch. Need to know where the correct port it.
   / Putting Accumulator on Farmall 110c 3 point hitch. Need to know where the correct port it. #1
screamin400
Platinum Member
Lee Center NY
2016 Mahindra 2538, 2016 Mahindra 2655, 2017 CaseIH 75C, 2021 CaseIH 110c., 2020 Kubota svl 65-2, 2022 Kubota svl 75-2, Kubota svl75-3, Kubota M6
I am putting an accumulator on my Farmall 110c for the 3 point hitch. I believe the port is right under the cab but no one at my dealership can tell me for sure. I have also heard it may mess with my draft control but will worry about that more when I figure out where to hook it in. I believe they would call this the pressure test port. I think all CaseIH Farmall C tractors are probably in the same spot but not positive. Anyone every install one on these tractors?
   / Putting Accumulator on Farmall 110c 3 point hitch. Need to know where the correct port it. #2
are your lift cylinders internal or external. you can just follow the hoses if they are external but if they are internal, hopefully someone with more knowledge of your specific tractor will chime in.
Mine are internal. Went and looked at a new 110c and they have spots to put externals bolt on. Two hoses coming out the back with plugs in them. Mine is 3 years old and does not have them :(
   / Putting Accumulator on Farmall 110c 3 point hitch. Need to know where the correct port it. #4
your dealer should be able to tell you what port is the test port for the three point lift circuit. you just need to tee into that circuit.
lots of snow removal contractors running around with accumulators on the 3pt hitch. they must have set up at least one, a good service manual should have the info you are looking for.
You would certainly think so. I finally went there earlier in the week and told them I was going to stand there until someone could look it up and point me in the right direction. They got the info for me and I hooked it up yesterday. This dealership is 5 stores and never done one for 3pt hitch.
   / Putting Accumulator on Farmall 110c 3 point hitch. Need to know where the correct port it. #6
May I ask reasoning for installing accumulator on 3pt hitch hyd circuit?
   / Putting Accumulator on Farmall 110c 3 point hitch. Need to know where the correct port it. #7
to avoid breaking the 3pt hitch when roading with a heavy attachment. most snow removal contractors use them up here. there is a safety valve in the 3pt hitch that protects from shocks but the properly setup accumulator also improves the ride greatly. it really smooths things out. I have a dual setup on my loader and one on the 3pt hitch.
I have one set at a lower pressure for when the loader is empty and one at a higher pressure when the bucket is full. some manufactures call them ride control or soft ride.
   / Putting Accumulator on Farmall 110c 3 point hitch. Need to know where the correct port it. #8
the amount of nitrogen pressure is important. not enough and it will bounce too much and if you have to much nitrogen pressure in it it won't really do anything. and of course it all depends on how much your attachment weighs.
   / Putting Accumulator on Farmall 110c 3 point hitch. Need to know where the correct port it. #9
Thank you for your explanation. I understand your reasoning.
   / Putting Accumulator on Farmall 110c 3 point hitch. Need to know where the correct port it. #10
Sure makes carrying heavy loads with the Kubota M59 FEL so much smoother. Just makes sense. Only very rarely do I valve the accumulators out to pallet fork a load or rigging steel. Guess with a 3pt system a manual or solenoid valve could be used to return the system to normal like with draft control.
Update: Years to get the answer I wanted and finally found a tech that knew right where it was. Put the accumulator on and it was awesome. So what do I do? I trade the tractor the next day. :) Got offered a great price on a Kubota m6-111 that I could not refuse. Now to find the test port on that one.
If anyone is looking into doing an accumulator on a Case tractor I ran 900 pounds of nitrogen in it. Blower hangs back a ways and weight in at 1900 pounds. Made a huge difference in ride.
   / Putting Accumulator on Farmall 110c 3 point hitch. Need to know where the correct port it. #12
At least the Kubota has external cylinders, so it should be easier to figure out.
I run an accumulator on the loader and can only recommend it. Definitely a game changer in how the tractor rides.
   / Putting Accumulator on Farmall 110c 3 point hitch. Need to know where the correct port it. #13
Yes a total game changer in the ride quality. And I don't even road my tractor very much but my trails in the woods are nice enough to drive fairly fast but are not perfectly smooth so it makes the Mod worth it for me. My cylinders were external so it was easier to T into the hose. I have a manual valve on my loader accumulator and 3pt hitch but I really would have liked to have a switch in the cab but so far I haven't felt the need to switch them off.
   / Putting Accumulator on Farmall 110c 3 point hitch. Need to know where the correct port it. #14
Something like this would make it easier to turn On or Off from the cab. You would have to choose if you want to normally closed or normally open.
I only turn mine off for the loader when I'm scooping dirt. Otherwise it tends to dig further than I want it to. But moving the full bucket with the accumulator there is such a breeze and should also take a lot of the shock load from the hub bearings.
2016 DRAGON SAND CONVEYOR (A58214)
2016 DRAGON SAND...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2018 FREIGHTLINER...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
UNUSED FUTURE 3T HYD TILT BUCKET (A60432)
UNUSED FUTURE 3T...
UNUSED SDLANCH 20'X20' HIGH END CARPORT (A60432)
UNUSED SDLANCH...
2008 KENWORTH T300 FLATBED FUEL TRANSPORT TRUCK (A58214)
2008 KENWORTH T300...
