Hydraulic hose bulge
/ Hydraulic hose bulge #22
Couldn’t find one at TS. Seems they have mostly 1/2” and I need 1/4” so I’ll order one online tonight. What are these fittings called? Both ends of the hose are female and have a flared in shoulder.
I’d change those adapters too. They aren’t expensive and with so much rust they probably wouldn’t seal correctly. It also looks like the thread is galled.
It looked like there might’ve been some Teflon around the threads. If I’m not mistaken these shouldn’t be put on with any sealant or tape right?
/ Hydraulic hose bulge #25
Definitely JIC (unless it’s JIS..), do not use thread tape. If you are near me I can make a hose on site in my service van. I’m in southern NH.
Many Napa stores offer made to order hydraulic hoses. Find the closest one and call them.
Where in NH are you? I’m in Madbury
/ Hydraulic hose bulge #27
Work in Merrimack, live near Plaistow. I don’t have a service call out your way anytime soon, but if you can swing by Plaistow after 4pm I’m happy to make you a hose.
That’s a bit of a hike but a solid plan b. I found one labeled “female JIC (37 DEG 7/16-20 thread”. Think that’s the one?
/ Hydraulic hose bulge #29
Couldn’t tell you unless I measure the fitting. -4 JIC thread is 7/16-20, -6 is 9/16-18.
If you used a 9/16 wrench to take it off; it’s a -4. If you used an 11/16, it’s a -6.
/ Hydraulic hose bulge #31
I’ve run into some manufacturers going up one size on the hex, Parker and Eaton are common offenders.
Going by the pic, it looks like -6 to me. But double check with a set of verniers and a thread gauge.
Im pretty sure the Napa near you in Dover carries hydraulic fittings, maybe call them tomorrow and see if they make hoses. If they do, they can duplicate yours no problem.
/ Hydraulic hose bulge #32
And replace that fitting! It looks like a 2404-6-6.
Tractor supply carries those in a pinch too.
/ Hydraulic hose bulge #33
Got this old backhoe last year for pennies. First thing I did was new filter and fresh transdraulic fluid. Probably put on 20 hours last year and an hour this week. Today I just needed to dig a small hole to plant a tree. I was able to finish the hole, pack it up and put the tractor back in its home before I realized this huge bulge. What’s going on here? It amazes me that I was able to finish digging the hole.View attachment 1345774
One other thing that can greatly contribute to early hose failure is improper hose routing. I wouldn’t rout the new one like the old rubbing against the lower hose, can’t be the original route. 1or 2 hose clamps securing it to the cylinder barrel be better I’d think.
Always eliminate abrasion points, twists and tight radius bends.Ive seen poor routing on new equipment that I’ve had to reroute.
/ Hydraulic hose bulge #34
I had a FEL. hose swell inside of it. A sharp bend in the routing. Pinch the Hyd flow almost off. After a Hyd. Filter and fluid change made it worse. Pulled it back down and Lucky I looked inside the hose. Suction to the pump. Holy wow!! when I seen it. Wasn't ballooned like that but swelled up!
2017 CAT 420F2 Backhoe (A63109)
2017 CAT 420F2...
All-Aluminum Timpte 720 Trailer (A63118)
All-Aluminum...
Ford 8210 (A60462)
Ford 8210 (A60462)
UNUSED WOLVERINE QC1-26-20G UNIVERSAL HITCH (A62131)
UNUSED WOLVERINE...
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A63109)
THIS WILL BE A...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
