RTV900 running hot
/ RTV900 running hot #1
Notforhire
Southwestern Virginia
Kubota L47TLB
It was in the low 80s today and I'm driving down the road pretty much flat out. I look at the temp gauge and it's in the red. There is a down hill slope ahead so I put the transmission in neutral. I coast for about 15-20 seconds and I watch the temp drop quickly to normal. All fluids are up and clean. The radiator and screen are clear. Could the transmission be making that much heat? Thoughts?
/ RTV900 running hot #2
Not sure about the transmission, I think I’d check the thermostat and make sure the water pump and belt are good. Radiator fan is worth a check too.
You are correct!
Turns out the thermostat was NG as well as the fan switch.
I replaced the temperature gauge with one that is easier to read and changed the thermostat. We were without power for a couple of days and our generator doesn't feed the shop so the fan switch was put on hold.
/ RTV900 running hot #4
You are correct!
Good to hear, glad you have it figured out.
ATS 40 Gallon 2 Stage Air Compressor (A62679)
ATS 40 Gallon 2...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A59823)
2018 FREIGHTLINER...
Cattle Feeder (A65640)
International 806 Wheatland Tractor (A66285)
International 806...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
2010 WABASH 53X102 REFRIDGERATED TRAILER (A59914)
2010 WABASH 53X102...
