RTV900 running hot
   / RTV900 running hot #1
Notforhire
Southwestern Virginia
Kubota L47TLB
It was in the low 80s today and I'm driving down the road pretty much flat out. I look at the temp gauge and it's in the red. There is a down hill slope ahead so I put the transmission in neutral. I coast for about 15-20 seconds and I watch the temp drop quickly to normal. All fluids are up and clean. The radiator and screen are clear. Could the transmission be making that much heat? Thoughts?
   / RTV900 running hot #2
Not sure about the transmission, I think I’d check the thermostat and make sure the water pump and belt are good. Radiator fan is worth a check too.
You are correct!
Turns out the thermostat was NG as well as the fan switch.
I replaced the temperature gauge with one that is easier to read and changed the thermostat. We were without power for a couple of days and our generator doesn't feed the shop so the fan switch was put on hold.
   / RTV900 running hot #4
You are correct!
Good to hear, glad you have it figured out.
2023 Vivid EV Golf Cart (A51694)
2023 Vivid EV Golf...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
2005 Mercedes-Benz C-Class Sedan (A50324)
2005 Mercedes-Benz...
5 Shank Inline Ripper (A50514)
5 Shank Inline...
2014 Jeep Cherokee SUV (A50324)
2014 Jeep Cherokee...
2023 TAKE 3 TRAILER 3 CAR TRAILER (A52141)
2023 TAKE 3...
