Vehicle Oil changes
/ Vehicle Oil changes #62
Here is an example why I can't trust anyone else to maintain my vehicles...Brother in law stops over to borrow a tool. I say hey it's September let me test your antifreeze while you're here. He says just had it at dealer for oil change. I grab my tester and his reservoir is so low I can barely get a sample. Added 1/2 gallon of correct red premix to it and inspected for leaks but found none. How is it possible to charge $70 for an oil change and not glance at clear reservoir right next to oil fill much less test for winter protection.
I had an oil change done at the Ford dealer in Wawa, ON. I got home, checked the oil on same floor I always check it where I park it and I was low. Had to buy two litres of oil. I called them and said, I'm not asking for anything, but maybe check your measuring equipment.
They got defensive and kinda ignorant about it, so I gave them a bad review when Ford emails you those satisfaction survey's.
Then all of a sudden they were calling offering a free oil change. I told them to keep it.
Also had the VW dealer put the hoiist through the floor of my wife's Jetta while in for an oil change. Then they tried to say she ran something over. You can see those pics of you google Northside VW Sault Ste. Marie and look at reviews.
/ Vehicle Oil changes #63
Pretty much since forever, I've always done my own oil changes in vehicles; except of coarse work vehicles. Wife got a 2019 Charger RT a while back, and it won't go on ramps, and Way to low to crawl under, so I've had my son run it up to the non-chain tire/lube place I take work car. It's always been expensive (IMO) at $120; but ok. Today, wife is Way over, no time to run it to the other place, 45 min away; so I steal it at lunch and run it to one of those, 5 minute, stay in your car, chain places. Da'Yum, $174, for basic synthetic, basic filter, and a $35 cabin air filter. Is it just me, or is that ridiculous. The $120 place; they atleast vacuum the car, and leave you a mint with a Bible verse on it; and I'm up there every 7500 miles with the work car. They are a but out od the way, and not that fast, but.....
Late to the thread, but I have the SRT Charger, with the even lower and longer chin spoiler... it doesn't love ramps, or even most intersections, it's often rubbing the pavement.
Anyway, I built wood extensions onto my steel ramps for my wife's R-design car, and those kinda worked for the SRT as well. Eventually though, I just bought some long (72" I think) Race Ramps, as they're so much nicer than old steel ramps. They're lightweight foam, 14" wide, so they stow perfectly between ceiling joists mounted 16" OC. They also take the wide tires of the SRT way better than any old steel ramps. Most importantly, being two-piece, you can pull away the lower half of the ramp after the car is up on them. This makes working on anything farther back much easier, with better access from the side.
I still do all of my own fluid changes on all of our vehicles and OPE. I don't care so much about the cost, but I don't have all day to waste driving to an oil change place and then waiting, times a half-dozen cars and machines every few months.
Looks like these from Vevor are relatively affordable, as long as you have a hydralic source already, and don't need to buy the AC hydro pump for the lift ramps too
Edit; I have been mostly happy with Vevor, but you Really need to triple and quadruple check the description, name, pictures, to confirm. Description says it comes with a 120v AC hydro pump, one picture shows it, one shows it as an accessory... I went through this with the 7x14 Lathe; you could have 8 separate items that appear identical, with major price difference, and the description didn't help, but when you zoomed in, you could see one had metal change gear, another had polymer, one came with cutting tools, another didn't, ect
/ Vehicle Oil changes #65
Late wife had a 2006 Jeep Commander. Took it in for service a the local quick change. Told them wanted Rotella T 10-40. Said NO, can't do that. Book does not call for it. Told them to use it anyway. Still no. Left and took it to the Dodge/Jeep dealer a mile away. Asked if they would use the Rotella. Service manager said sure, no problem. I've used Rotella/Ursa in my gas engines since the late 60's.
/ Vehicle Oil changes #66
IMHO you should never flush out your transmission if its an
older model as there might be some sludge and it could get
jamed into a part of transmission and cause damage that you have to have a new transmission. Just a known fact!
willy
/ Vehicle Oil changes #68
Low profile Jack and Jack stands
/ Vehicle Oil changes #69
Actually that is cheap for an oil change.
Every time mine takes hers in, it costs $600.
A fool and his money are soon parted. $600 is extremely high for an oil change, does she go to the one with the free use of the cabana boy?
/ Vehicle Oil changes #70
You can get ramps for low-clearance cars. I've had a set for years for my Corvette. Mine are in two sections for each side that can be disconnected for storage between uses. The lift is gradual so you can drive up on them without ripping up spoilers, etc.
/ Vehicle Oil changes #72
At $174 per oil change, I start thinking one of those garage lifts would be a better investment long term, especially considering that the oil change place could strip your oil drain threads.
I'd have a 4-post now if I had a way to get it off the truck. They won't drop it with a lift gate, and it weighs too much for my tractor w/FEL. They said have it delivered to a business and pick it up with a trailer. I said, I don't have a trailer and how would I get it off the trailer if I did have one? :rolleyes: 😏
/ Vehicle Oil changes #73
Yes, too high for me. I take my sierra to the chevy dealer. 8 qts. Detox full synthetic for $125 plus they rotate tires, top off fluids, check brakes, exhaust and other things and send you a video of them doing it. Last time I bought a coupon for 3 oil changes for $250.
/ Vehicle Oil changes #74
That is really high for around here. Local dealer charged $58 out the door for my F150 and $63 out the door for wife's Yukon; and we didn't have any coupons.
/ Vehicle Oil changes #75
My dealerships are about a 30 minute drive away so that would turn a short job into at least 90 minutes with transit time and waiting at the dealership. I bought a set of 2 piece Race Ramps when I took delivery of my 2016 Corvette Z06 and I also use these for my Camaro and Cadillac CT5 V. Once the car is up on the ramp, the drive up section removes for full access.
My GMC 2500HD diesel has plenty of room underneath without ramps as does my Deere compact utility tractor and Kubota F series mower :) The diesel genset is easiest of all since it came from the factory with a drain valve and hose.
Rodger
/ Vehicle Oil changes #76
You unload it off the truck one piece at a time. Either use your front end loader or get some friends to help.
I watched Halfassed Customs (YouTuber) assemble several of his by himself with a telehandler. I know if I bought one it wouldn't take long to have it set up.
/ Vehicle Oil changes #77
I've been using the dealer for that "maintenance history" since I bought my Accord new. They had been at ~$54 per change but recently is in the $80 range. Not convenient at 30 mins each way, but seemed reasonable before the price increase. I just had a lift installed in my new shop a week ago, so going forward I'm going to have to figure out the maintenance minder and change it myself.
edit: 2 post rotory brand 10k lift was $7500 installed by the dealer. Not as cheap as some in this thread, but should pay for itself.
/ Vehicle Oil changes #78
I spoke with the vendor about doing just that, but he says it varies by trucking companies. Most won't give you the time to break down a crate in-truck to do that. It all depends on the local terminal and what trucks they have available at the time. The driver might have something to say about it too--He's on a schedule.
/ Vehicle Oil changes #79
I won't let anyone change mine. I made some ramps. used 2x10's stacked on top of each other, each one 2.5" shorter then the other. 3 of em. raises the car up 4.5" which is enough to get under my vehicles. I only use pennzoil,mobile one or quaker state (FULL synthetic) depending on which is the cheapest at the time since prices on oil is always up & down. and I use a quality filter. with the better oil no need to change every 3000 miles. these are rated up to 15000 miles. but I still change mine at 4500 now
/ Vehicle Oil changes #80
My mistake. I assumed it was off of your own truck. You don't have a friend with a truck and trailer? I know if transport was my only problem I'd find a way to make it happen.
UNUSED ATS DJ2200 ELE. LIFTING MOTOR (A62131)
UNUSED ATS DJ2200...
New/Unused Wolverine 72in Quick Attach Grapple Bucket (A61166)
New/Unused...
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A62131)
UNUSED WOLVERINE...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63118)
2017 Cadillac...
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A62129)
2014 CATERPILLAR...
