What Attachment Scares You The Most?
   / What Attachment Scares You The Most? #1
Runner
Elite Member
Missouri
2024 Cub Cadet Ultima ZTXS5 54, 2007 John Deere 2520, 1989 John Deere 185, 1960 Panzer T70B
Believe it or not, my weight box scares me the most. It is the heaviest attachment I have (809 lbs), and if it falls, it is going to do some damage to anything it hits. I usually keep it on a wooden dolly with steel casters, and moving it around, even on the concrete floor is scary to me because I have had casters fail before. I am deathly afraid of having my feet or any other body part anywhere close to that box.
   / What Attachment Scares You The Most? #2
Believe it or not, my weight box scares me the most. It is the heaviest attachment I have (809 lbs), and if it falls, it is going to do some damage to anything it hits. I usually keep it on a wooden dolly with steel casters, and moving it around, even on the concrete floor is scary to me because I have had casters fail before. I am deathly afraid of having my feet or any other body part anywhere close to that box.View attachment 1159275
Another owner with a folded ROPS that is doing nothing far as protection is concerned.
   / What Attachment Scares You The Most? #3
Trencher is probably the most dangerous attachment that I have, it has been used to grind stumps and requires a lot of attention when using it. Spinning blades throwing stuff at the back of the tractor, not a good feeling!
David from jax
   / What Attachment Scares You The Most? #6
The SS brush hog has spinning blades reaching out 8" in front of the housing. It cuts anything like butter but those exposed blades and open front where it throws debris make me nervous.
Actually it makes a really good place for me to hang my hearing protection when not in use running the chipper.
So you protect your ears but not your head? :LOL:
Last time I looked, after 17 years of running this machine, my head was still intact. :cool:
   / What Attachment Scares You The Most? #10
So far so good. That is no guaranty of the future. But you have the choice to not use it. Like not using a seat belt. You do you. It doesn't prevent other people from noticing.
True, and if I was worried about what other people thought, I would put my ROPS up before taking the picture. Just like anything else I ever post, I'm not recommending it for anyone else, just what I do/think.
And, just for the record, I DO use my ROPS in the deployed position, when I believe it to be prudent.
   / What Attachment Scares You The Most? #13
protection ? from asteroids I am assuming, its certainly not from tipping his driveway looks implacably level.
And that 800 pound weight 4-5 ft above the ground 10 ft out past the lift point could not possibly affect the stability, right? lol
   / What Attachment Scares You The Most? #14
My top 2 are my square bailer and post auger I would say... I fell pretty safe with the brush hog but certainly don't let anyone stand behind it while I operating it.
Well, the 675lb mower on the back and 360lbs of wheel weights help a little....
   / What Attachment Scares You The Most? #18
Op: Sounds like your initial post/ thread is describing your opinion of your scariest unmounted attachment.
Most replies would probably be for attached running implements.
   / What Attachment Scares You The Most? #20
My garden tiller.
We don't know what is buried under our feet. Mechanically disturbing 6" of soil could get expensive.
For that reason, I quit tilling for hire.
2014 Forest River Rockwood Premier 2317G S/A Pop Up Trailer (A59231)
2014 Forest River...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
Freightliner Fuel Truck (A56438)
Freightliner Fuel...
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
2025 14ft. Bi-Parting Driveway Gate (A59231)
2025 14ft...
2014 Ford Edge SUV (A56859)
2014 Ford Edge SUV...
