What Attachment Scares You The Most?
   / What Attachment Scares You The Most? #1
Runner
Elite Member
Missouri
2024 Cub Cadet Ultima ZTXS5 54, 2007 John Deere 2520, 1989 John Deere 185, 1960 Panzer T70B
Believe it or not, my weight box scares me the most. It is the heaviest attachment I have (809 lbs), and if it falls, it is going to do some damage to anything it hits. I usually keep it on a wooden dolly with steel casters, and moving it around, even on the concrete floor is scary to me because I have had casters fail before. I am deathly afraid of having my feet or any other body part anywhere close to that box.
   / What Attachment Scares You The Most? #2
Believe it or not, my weight box scares me the most. It is the heaviest attachment I have (809 lbs), and if it falls, it is going to do some damage to anything it hits. I usually keep it on a wooden dolly with steel casters, and moving it around, even on the concrete floor is scary to me because I have had casters fail before. I am deathly afraid of having my feet or any other body part anywhere close to that box.View attachment 1159275
Another owner with a folded ROPS that is doing nothing far as protection is concerned.
   / What Attachment Scares You The Most? #3
Trencher is probably the most dangerous attachment that I have, it has been used to grind stumps and requires a lot of attention when using it. Spinning blades throwing stuff at the back of the tractor, not a good feeling!
David from jax
   / What Attachment Scares You The Most? #6
The SS brush hog has spinning blades reaching out 8" in front of the housing. It cuts anything like butter but those exposed blades and open front where it throws debris make me nervous.
Actually it makes a really good place for me to hang my hearing protection when not in use running the chipper.
So you protect your ears but not your head? :LOL:
Last time I looked, after 17 years of running this machine, my head was still intact. :cool:
   / What Attachment Scares You The Most? #10
So far so good. That is no guaranty of the future. But you have the choice to not use it. Like not using a seat belt. You do you. It doesn't prevent other people from noticing.
2017 Ford F-150 Pickup Truck (A55973)
2017 Ford F-150...
2009 FORD F-250 XL SUPER DUTY FLATBED TRUCK (A58375)
2009 FORD F-250 XL...
Allmand Towable Light Tower (A56857)
Allmand Towable...
WOOD GRABBER FOR MINI EXCAVATOR (A58216)
WOOD GRABBER FOR...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58216)
2014 MAGNUM...
