What Attachment Scares You The Most?
   / What Attachment Scares You The Most?
So far so good. That is no guaranty of the future. But you have the choice to not use it. Like not using a seat belt. You do you. It doesn't prevent other people from noticing.
True, and if I was worried about what other people thought, I would put my ROPS up before taking the picture. Just like anything else I ever post, I'm not recommending it for anyone else, just what I do/think.
And, just for the record, I DO use my ROPS in the deployed position, when I believe it to be prudent.
   / What Attachment Scares You The Most? #13
protection ? from asteroids I am assuming, its certainly not from tipping his driveway looks implacably level.
And that 800 pound weight 4-5 ft above the ground 10 ft out past the lift point could not possibly affect the stability, right? lol
   / What Attachment Scares You The Most? #14
My top 2 are my square bailer and post auger I would say... I fell pretty safe with the brush hog but certainly don't let anyone stand behind it while I operating it.
Well, the 675lb mower on the back and 360lbs of wheel weights help a little....
   / What Attachment Scares You The Most? #18
Op: Sounds like your initial post/ thread is describing your opinion of your scariest unmounted attachment.
Most replies would probably be for attached running implements.
   / What Attachment Scares You The Most? #20
My garden tiller.
We don't know what is buried under our feet. Mechanically disturbing 6" of soil could get expensive.
For that reason, I quit tilling for hire.
2007 FREIGHTLINER M2 26FT BOX TRUCK (A59575)
2007 FREIGHTLINER...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
Mini Skid 48in Root Rake Grapple Attachment (A56436)
Mini Skid 48in...
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
