sd455dan
Super Member
- Joined
- Oct 23, 2012
- Messages
- 6,325
- Location
- North Idaho
- Tractor
- Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
Yes, coop's are good in that we rarely have outages....and when we do they are short-lived.
IF you are liking an adjustable ground mount...I would look no further than Sinclair sky-rack Sinclair Designs & Engineering - Michigan's leading Solar Racking Manufacture
I saw those experiments too of vertical mounting. Yes total production is less.....but a combo of vertical and horizontal can really flatten a curve and have good production ALL day. But from what I saw the single biggest benefit of vertical was still allowing use of the land between the panels for farming crops that dont get tall. Like hay being the biggest one
Well after kicking around the idea of trying to build a wood tiltable rack and then use uni strut to put under the panels to save money, I have been convinced that 'time' has value as well and as the wife says we aren't getting any younger, my engineering may fall way short...and we can get it installed ourselves before the ground freezes.
So... in the morning planning on getting the tiltable Sinclair Sky Rack 2.0 system ordered and on the way.
Thanks for the tip LD1.
After looking around this really does seem to be the perfect match for what I want to do and should be much easier to get the panels up and running sooner as well. Long life design and quality mount is worth it.
