Do my loader hydraulics need sealant?
   / Do my loader hydraulics need sealant? #1
future_vision
Gold Member
New England
DK6010SE HSA
Swapping out the upper cylinder on my Kioti DK6010SE. Curious if those hydraulic hoses sealant or not.
   / Do my loader hydraulics need sealant? #3
Only pipe fittings need sealant. Most others use gaskets or metal to metal.
Not sure how well these can be seen in this picture but these are the two fittings.
   / Do my loader hydraulics need sealant? #6
NPT(pipe thread)needs sealant(not teflon tape),tapered threads do not(metal to metal).
   / Do my loader hydraulics need sealant? #7
I don't remember the name of it but when I did some fitting replacement the thread sealant was listed for hydraulic lines.
   / Do my loader hydraulics need sealant? #8
I'm not aware of any hydraulic hose fittings that need sealant. I've heard that if you use sealant, you risk it getting into your hydraulic system, and potentially causing issues.
   / Do my loader hydraulics need sealant? #9
Tapered threads need something, tapered seat fittings (SAE/JIC) do not need sealant, and if there's O rings then those do not need sealant either.
On tapered threads tape is fine if used CORRECTLY which most people don't do, the tape should start one thread back so none get into the medium inside... Thread sealant is a lubricant and a sealant so it covers both but some people use tape and sealant...
   / Do my loader hydraulics need sealant? #10
Only tapered threads (NPT) need sealants.... Tape or paste or fluid (locktite?) .. Straight threads do not "seal" they provide pressure to make a metal to metal contact seal (like JIC connection) or use some sort of gasket ("O" Ring?) to make seal..
Mini Skid-Steer Hydraulic Side Shifting Forks (New/Unused) (A59225)
Mini Skid-Steer...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
2025 Swict 60in Bucket Skid Steer Attachment (A56857)
2025 Swict 60in...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
2017 Ford F-750 Crew Cab Terex Hi-Ranger 6TC-65 65ft Insulated Bucket Truck (A56858)
2017 Ford F-750...
