Do my loader hydraulics need sealant?
   / Do my loader hydraulics need sealant? #11
Tapered threads need something, tapered seat fittings (SAE/JIC) do not need sealant, and if there's O rings then those do not need sealant either.
On tapered threads tape is fine if used CORRECTLY which most people don't do, the tape should start one thread back so none get into the medium inside... Thread sealant is a lubricant and a sealant so it covers both but some people use tape and sealant...
Never quite understood using both, see a lot of "Facebook Plumbers" doing that.....
   / Do my loader hydraulics need sealant? #12
I use teflon pipe sealant paste, works great.
   / Do my loader hydraulics need sealant? #13
The hoses themselves are self sealing. Usually they have 90 degree fittings that screw into the cylinders. Some machines have O rings on those fittings but pipe thread that requires sealant is more common.
Just went for it. The existing fittings didn't have sealant. There was also an o-ring inside so i think I'm good with just tightening.
Thanks everyone
   / Do my loader hydraulics need sealant? #15
Thanks everyone
The 90 degree elbows threads into the boss on the cylinders, then the nut, is actually a jam nut with a o-ring inside. This provides the sealing of the fitting and also allows you to rotate the 90 degree elbow to whatever position you need.
The hose seals on the elbow using a taper.
No need to any sealants on those fittings.
   / Do my loader hydraulics need sealant? #16
I was assuming that everyone knew that O-rings are the sealing method where they are used. The sealant I mentioned was for threaded connections such as where a Pioneer male or female fitting is screwed onto a pipe.
   / Do my loader hydraulics need sealant? #17
Thanks everyone
Did you replace the O-Ring? From what I understand, they have to be replaced every time you take off the hose because they become crushed when tightened.
I have a kit that I bought from Amazon with a huge selection of O-Rings to choose from. It even came with a few tools for getting the O-Rings off that's very handy.
   / Do my loader hydraulics need sealant? #18
   / Do my loader hydraulics need sealant? #19
Loctite 545 (purple) is for NPT hydraulic threads. Only NPT fittings need anything. It isn't required to use, but helps stop any small leaks or weeping. Cylinder fittings are often NPT, but not always
I didn't but probably should have. I'll keep an eye out for leaks and replace since I have one of those o-ring kits from Harbor Freight
JOHN DEERE Z530M LOT IDENTIFIER 160 (A53084)
JOHN DEERE Z530M...
MARS AIR DOORS TAN BANK (A51248)
MARS AIR DOORS TAN...
PALLET OF PORTABLE AC UNITS (A51248)
PALLET OF PORTABLE...
2018 Nissan Sentra Sedan (A51694)
2018 Nissan Sentra...
2016 Ford F-550 Ext. Cab Flatbed Truck (A52377)
2016 Ford F-550...
2017 Caterpillar D5 K2 LGP (A53473)
2017 Caterpillar...
