New garage time!
/ New garage time!
Ditched the ground spikes idea when i decided to run conduit so I can pull fiber lines.
Busted through the basement wall right where I wanted. Put a 1" pvc through for the pex, and a 1.5" on top of it for the fiber lines. Glue'd all the conduit and letting it set overnight, taped the pex to the conduit so it'll be ready to drop in tomorrow.
/ New garage time! #1,322
You lost me at fiber optic. Do you already have that in your house? are you running it out to the patio from your house? What is it for?
/ New garage time!
10gb internet to the shop. Right now I have a wifi range extender on the back porch that beams to the shop and a receiver in the shop so that it has wifi, but it's a rigged setup, and it's slow.
/ New garage time! #1,324
1. Wi-Fi extender as in Wi-Fi received at the back porch and Wi-Fi out to the shop?
or
2. Wi-Fi access point as in Ethernet cable to the back porch and Wi-Fi out to the shop?
or
3. Bridge with Ethernet cable to the back porch, a bridge pair with a unit on each side and Ethernet again at the shop?
Sorry, for the questions, but I am going to replace my Powerline adapter pair (ethernet runs on electrical cables to the shop), which cannot handle the data bursts from my security cameras and am looking at the 3rd option above. I would agree option 1 could be very slow.
What I have and what I am looking at to replace it with
/ New garage time!
or
or
View attachment 979626 View attachment 979627
Right now i have a range extender on the back porch and inside the shop, and it's not nearly fast enough to handle the cameras, or even an HD stream.
I've heard good things about hte powerline adapters, but haven't tried them myself since the phone line days. Yes, they did exist when dialup was a thing. I've been told they have to be on the same circuit, or at least the same leg of the panel, to work. Again, untested.
That's why I'm running sfp+ between two switches. I have 6 cameras on the shop and inside, plus my firestick and laptop. So I'll be running 10gb sfp+ over fiber or copper
/ New garage time! #1,326
Thanks. I'd do the same thing you are doing if my space between buildings was not concrete.
As far as the powerline carriers go, mine do better on the same leg of the power but have troubles on both. I originally tried both since both conductors running out there are black.
/ New garage time!
Well now i'm in thailand. I saw this last time, but wasn't sure. It's a tankless hot water for $75. Thailand runs on 220v. Everyone has them, next to their shower.
I was thinking I could get this to adapt to my radiant floor for the shop. I think it's just a simple heating element and rheostat, no electronics involved. I'll pick it up tomorrow and bring it back to the hotel and open it up. If it's what I think it is. I think I'll get one for the house as well next to my shower. That way I don't need an oil fired hot water heater.
/ New garage time! #1,328
From what I've read, the electric instant hot water heaters use so much power to heat the water that there isn't a savings using them over a conventional electric hot water heater. The real savings with instant hot water heaters is with Natural Gas or Propane. Especially if you have the supply line big enough to supply the amount of gas needed.
/ New garage time!
I have no ng or propane even at my house. It will have to be electric one way or another. I plan to power it with solar as primary but supplemented with grid.
/ New garage time!
Got my hot water heater, time to unbox it and take it apart and see what I find inside. Heating elements are amazingly simple, i should be able to power one with ac or dc. Then it's just a matter of flow control module, and a circulation pump.
/ New garage time! #1,331
We've had Natural Gas at the first house, LP and Electric here. Present WH is Electric, but will replace it with LP if it dies before I do. We have a 1,000 gallon LP tank and use only around 450-500 gallons for heating.
Side note - A few weeks ago we left the house on a Tuesday and returned late Friday. I turned the power to the WH off before we left. Had to wash my hands when we got home and the water was still piping hot.
/ New garage time! #1,332
Are you running pre-terminated fiber or do you have means to terminate your fiber strands? I figured out a way to get to my shop doing an "end run" (out the other side of the house and around) that avoids the concrete between the house and shop. It is within the 100M cat5e distance limitation, but fiber would be better. If pre-terminated, where do you get custom length fiber?
EDIT: I found Landshack.com sells pre-terminated fiber AND with a pulling sock over staggered connectors. Nice.
/ New garage time!
I got into my tankless hot water heater to look around. It's exacxtly what I was hoping for. Flow control circuit, heating element, rheostat, and not much else. Perfect for something I can gut and repurpose for my needs. and $75 is a steal for it. Assuming it actually does 4500w.
/ New garage time!
Back to business and back in america., heating system will be another thread when it gets underway.
Ground anchors all installed, 1/2 wall anchors installed. Making all these brackets as I go. Each anchor is 1/2"x4" so it should have plenty of grab.
/ New garage time!
Way too long, but nice perspective from the Drone.
Yes but i havent' figured out how to edit yet. Once I do, watch out.
Here's 1 hour and 7 minutes of chickens eating pumpkins.
/ New garage time! #1,339
I had to fast forward to see how much they ate in an hour and 7 minutes.
/ New garage time!
It was about 4pm, so they were pretty much done eating for the day. I should have taken it out at 7am, they probably would have cleaned it in an our with the rinds left.
3ft Teakwood Totem Pole (A65583)
3ft Teakwood Totem...
2001 Blaw-Knox PF 150 Paving Machine  (A62679)
2001 Blaw-Knox PF...
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
2014 Ford F-150 Pickup Truck (A64556)
2014 Ford F-150...
2005 Ford F250 Super Duty XLT (A66408)
2005 Ford F250...
2015 Mercedes-Benz C300 Sedan (A64557)
2015 Mercedes-Benz...
