New garage time!
/ New garage time! #1,302
So I'm going to run power to the shop, real power. My house has 200a service, 100a per leg. I want to run full power to the shop, all 200a. The reason for that is I eventually want to generate all of my power in the garage, and backfeed the house, so I want the ability to send it all both ways.
I used this site: https://paigeconnected.com/calculators/wiresize-calculator
This said I need 1/0 copper or 4/0 aluminum.
So I found this: SWEETBRIAR-CUT :: Sweetbriar, (2) 4/0, (1) 2/0, Aluminum, Cut to Length :: Rexel USA
so I think I'm going to go with that.
I think 200a @ 240v of solar is a lot of panels. When I ran PVwatts for a 16kw array it said it will make a max of 45 amps (240v) at full output on June 21. If the 16kw array makes an actual 16kw, that's still only 66a @ 240v.
/ New garage time!
Other side done. Much faster this time. Tweaked the saw so it's making better cuts and quicker.
I ordered a new mask and welding shirt, so I don't have to collect slag with my bare skin.
/ New garage time!
Other side done. I picked up this plank to put between ladders to make it less safe. It's coming slowly because it's a lot of up and down the ladder, every piece is bolted up, measured, marked, and cut by hand, then back up the ladder, and welded in place.
And I built another of these mud kitchens for underprivileged kids that my wife keeps wanting me to build.
/ New garage time!
Doing this with one person, in the dark, in the rain, on a ladder is proving to be slightly dangerous.
So I switched gears to work on my battery, bms, and busbar setup.
I have a JK 100a bms, my busbars are 12" copper. I am installing 4 growatt 3k bms and 6 15kwh batteries. I'll drill and tap the bus bars every inch giving me a total of 11 holes.
The BMS has 2 10ga leads for the battery, but I was under the impression I needed 1ga copper for my battery wire. I feel like the 2 10ga is on the small side.
I am currently top balancing my 280ah batteries, I have a feeling it will take a while.
/ New garage time!
Had to redesign the cross member support. The webbing doesn't work for the side to side cross members. So I needed to add some stubs down then diagnoal supports to support the load. Then a horizontal support to pull it together.
Doing it on paper is easy, but everything is heavy trying to clamp in place so I can tac it in place. I want to pick up some T channel for the diagonal, I don't think the flat stock is strong enough over this distance.
/ New garage time!
Playing with a couple different designs, I think a joist style might work better.
/ New garage time!
Strength is important, but really the strength is already there. I'm just looking to combat sag. Over the span there's about 1cm of drop. Since this will be covered in panels which are rigid, sag may compress them and result in cracks. That's the biggest thing I'm trying to avoid.
In the first design, the outer two triangles will keep it supported mostly, but it can pivot, without the lower horizontal member. The lower horizontal pulls it together.
With truss design trusses sag all the time. They're still strong enough, but I'm looking more for rigidity and resistance to sag. I think the original design is the strongest.
/ New garage time! #1,312
I'm jealous of your scaffolding. I can't count how many times I've told myself to buy a couple sets, and even gone to the store to look at it, and then decided not to spend the money. One of these days, I really need to spend the money!!!!
/ New garage time!
It saves so much energy compared to a ladder. Also gives me a place to set the welder. I wasn't going to break it out but this ended up being a bigger job than I thought. Every piece needs put in place, clamped, marked, unclamped, cut, welded. It's a lot of up and down, which takes a lot of energy.
/ New garage time! #1,314
I'm dealing with ladders all the time. I have more then I thought possible, but they all get used. It's just a pain moving them around, and not having a decent place to put anything.
Seems like they sell for the same price used as they do brand new!!!
/ New garage time!
They definitely do. I have a lot of ladders and they all get used, but working for an extended period of time with heavy stuff, it gets old. Fatigue on the feet.
The biggest pain is no where to put the welder, the leads are not that long to have the base on the ground and weld 13' up. I got hte platform hoping it would help, but still not great
/ New garage time!
Finally got the 3rd support structure done. I had to cut the last piece 3 times, wasting a lot of material. The first time I somehow cut it backwards despite holding it up and marking. The second I took my eyes off hte bandsaw for a minute and cut through. 3rd was ok.
Also cut and drilled mounting ears for the panel racking and ground anchors. I'm going with 1/2x8" anchors, 2 per leg. That should hold it down.
/ New garage time!
Picked up some 2-2-2-4 URD wire. Broke out the trencher. Went to disconnect the pool power wire. got my sharp knife out and was cutting the electrical tape pulling towards me and thought, this is dangerous. Then immediately it slipped, knife went into my index finger right at the first digit. It stopped when it hit bone. That bled, a lot. All over my clothes, ground, kitchen, wife. She was not happy.
/ New garage time!
I needed to clean the trench out of all the loose stuff. I tried a 2x4, that didn't work. And a piece of angle iron was heavy. so I made a 3.5" hoe with an 8' handle.
/ New garage time!
Tonight I made ground spikes. I cut the flat stock at 8", then bent it in my home made metal brake. Then wrapped it in electrical tape and cut a spike.
They'll be used to hold the water pipe to the bottom of the trench. I have 4" of sand and my depth is 28", where my frost line is 24". I have 300' of 1/2" ob pex so i'll have some room to screw up.
I'm also going to toss a pair of cat6e in.
/ New garage time! #1,320
Sorry to hear about the blood loss. Hope your tetanus is current. Back when I was doing trench work we modified shovels by heating them and bending the sides up to form a scoop.
2022 YANMAR VIO80-1A EXCAVATOR (A63276)
2022 YANMAR...
16ft. Aluminum Extension Ladder (A65640)
16ft. Aluminum...
New/Unused Spirit Electric Tricycle (A65583)
New/Unused Spirit...
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
2022 Ram 3500 Hauler Truck, VIN # 3C7WRTCLXNG270348 (A65563)
2022 Ram 3500...
(4) Kinze Gauge Wheels (A65640)
(4) Kinze Gauge...
