looking at used JD 3720 or 5045E tractor
/ looking at used JD 3720 or 5045E tractor #21
I bought one about a year ago. I've put about 50 hours on it. I like it so far, and the only issue is the fuel gauge does not work. We replaced the fuel sensor when I bought it, but the new one didn't last very long.
Here is a link to a thread I started when I got it. My first John Deere
/ looking at used JD 3720 or 5045E tractor #22
i had a 3720 for a few years. Never had an issue. Cons. I had a cab and it seemed a bit top heavy being a smaller tractor on hills and divots. the front tires are small too. they tend to spin easy in the snow - with R4s.
/ looking at used JD 3720 or 5045E tractor #24
A couple of differences compared to a 3720. Looks like it can be a manual transmission or a hydro. Looks like the engine has a turbo. Similar specs though.
Locale dealership wants us to look at a 5045E with 500 hours. Have to admit, it does have more of everything! (weight HP etc)
/ looking at used JD 3720 or 5045E tractor #27
Now that is a machine!
3320 was a huge step up in the burbs for me. Now that I have acreage , it is the smallest I would want (and punches high enough that I’m happy)
But, if I had to step up it would be something like that!
Maybe overall cheaper also( comparing weight/hp) as these CUTs are overpriced imho
Its a used 5045E the dealership has on hand.
/ looking at used JD 3720 or 5045E tractor #29
no cab on mine gets cold but nice for getting on n off in the summer , next one i get will have a cab
/ looking at used JD 3720 or 5045E tractor #30
Anyone here have one?
I have a 5055e from 2009. I like it and pretty much free of problems. I'm in the south so I pulled the cold start sensor cable off when I started having starting problems instead of replacing the sensor. I have a backhoe for it and the loader will lift 3000#.
I'd guess the 385 Backhoe. How does it work for you? How long and difficult to take on-n-off?
Because of mainly summer and backhoe use, was thinking open station would be best.
/ looking at used JD 3720 or 5045E tractor #33
/ looking at used JD 3720 or 5045E tractor #35
where are you located? gets darn cold here in North Dakota , been a goog tractor though
/ looking at used JD 3720 or 5045E tractor #38
The 447 hoe has been flawless. I've dug septic tanks, water lines, power cables and a lot of tree stumps. No failures. Only once did I wish it had a more power when I was ripping on a large tree stump. I eventually got it out.
How long does it take it get on on and off?
/ looking at used JD 3720 or 5045E tractor #40
I’m just about to trade a 2016 3039R HST for a new one. The dealer doesn’t care if I sell it before my new one is ready for delivery.
$29k with 950 hours, 385A backhoe, 18”HD bucket, H165 loader, 61”HD b let and bolt-on cutting edge & R4 tires.
2014 FORD F-150 (A60736)
2014 FORD F-150...
2020 MACK P164T (A58214)
2020 MACK P164T...
2020 DRAGON ESP...
2020 DRAGON ESP...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
