looking at used JD 3720 or 5045E tractor
   / looking at used JD 3720 or 5045E tractor #62
I think that you will find that the std skid steer attachments are far more plentiful and usually less money.
Just an FYI. ;)
   / looking at used JD 3720 or 5045E tractor #63
When you "back blade" with a bucket. It doesn't tug against those lock pins?
It does, but it's a non-issue.
The JDQA system is lightweight, extremely simple, and well proven in the ~30 years it's been around. Any implement you can effectively use on a CUT is readily available in that format.
   / looking at used JD 3720 or 5045E tractor #64
I have over 600’ of gravel driveway that I back drag for maintenance and snow
In nearly 20 yrs of use, no issues, no damage or discernible wear with routine maintenance
It is well designed for the size of the machine
2008 TOYOTA Camry Solara (A59231)
2008 TOYOTA Camry...
2019 CHEVROLET SILVERADO 11FT FLATBED (A59905)
2019 CHEVROLET...
16ft. Canoe w/ 12ft. Trailer (A59231)
16ft. Canoe w/...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
2018 International WorkStar 7500 Aquatech B-15 Combination Sewer Jetter Vacuum Truck (A59230)
2018 International...
