looking at used JD 3720 or 5045E tractor
/ looking at used JD 3720 or 5045E tractor #21
I bought one about a year ago. I've put about 50 hours on it. I like it so far, and the only issue is the fuel gauge does not work. We replaced the fuel sensor when I bought it, but the new one didn't last very long.
Here is a link to a thread I started when I got it. My first John Deere
/ looking at used JD 3720 or 5045E tractor #22
i had a 3720 for a few years. Never had an issue. Cons. I had a cab and it seemed a bit top heavy being a smaller tractor on hills and divots. the front tires are small too. they tend to spin easy in the snow - with R4s.
/ looking at used JD 3720 or 5045E tractor #24
A couple of differences compared to a 3720. Looks like it can be a manual transmission or a hydro. Looks like the engine has a turbo. Similar specs though.
Locale dealership wants us to look at a 5045E with 500 hours. Have to admit, it does have more of everything! (weight HP etc)
/ looking at used JD 3720 or 5045E tractor #27
Now that is a machine!
3320 was a huge step up in the burbs for me. Now that I have acreage , it is the smallest I would want (and punches high enough that I’m happy)
But, if I had to step up it would be something like that!
Maybe overall cheaper also( comparing weight/hp) as these CUTs are overpriced imho
Its a used 5045E the dealership has on hand.
/ looking at used JD 3720 or 5045E tractor #29
no cab on mine gets cold but nice for getting on n off in the summer , next one i get will have a cab
/ looking at used JD 3720 or 5045E tractor #30
Anyone here have one?
I have a 5055e from 2009. I like it and pretty much free of problems. I'm in the south so I pulled the cold start sensor cable off when I started having starting problems instead of replacing the sensor. I have a backhoe for it and the loader will lift 3000#.
I'd guess the 385 Backhoe. How does it work for you? How long and difficult to take on-n-off?
Because of mainly summer and backhoe use, was thinking open station would be best.
/ looking at used JD 3720 or 5045E tractor #33
/ looking at used JD 3720 or 5045E tractor #35
where are you located? gets darn cold here in North Dakota , been a goog tractor though
/ looking at used JD 3720 or 5045E tractor #38
The 447 hoe has been flawless. I've dug septic tanks, water lines, power cables and a lot of tree stumps. No failures. Only once did I wish it had a more power when I was ripping on a large tree stump. I eventually got it out.
How long does it take it get on on and off?
/ looking at used JD 3720 or 5045E tractor #40
I’m just about to trade a 2016 3039R HST for a new one. The dealer doesn’t care if I sell it before my new one is ready for delivery.
$29k with 950 hours, 385A backhoe, 18”HD bucket, H165 loader, 61”HD b let and bolt-on cutting edge & R4 tires.
2021 Bobcat T770 Compact Track Loader (A61166)
2021 Bobcat T770...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63118)
2023 Takeuchi TL6R...
2023 John Deere 6R 145 Tractor (A63109)
2023 John Deere 6R...
TPL MECHANICS BODY LUBE SKID (A62130)
TPL MECHANICS BODY...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
(2) 380/85R28 TIRES W/10 LUG RIMS (A62130)
(2) 380/85R28...
