Branson PTO fuses and coil
/ Branson PTO fuses and coil #12
It should as long as the PTO is running. It could be a bad light for the PTO but since you have no PTO working, could be something else. Most likely electric. Either a bad fuse, wires, switch or relay.
I don't think it's the solenoid because it usually still turns the light on even if the solenoid is bad.
Any suggestions on how to troubleshoot this?
Is there a wiring diagram I can download somewhere?
/ Branson PTO fuses and coil #14
Try finding the manual on the link that Lou provided. I believe the correct one is named: 1020 series chassis.
Here is the diagram:
That "A" that comes out of the solenoid, goes to the PTO Lamp. So I suspect your issue is behind that. Either the relay, switch, fuse or just a bad wire/connector somewhere. You really have trace it down but I would start with the fuse for sure.
/ Branson PTO fuses and coil #15
Wow, this is a great help! the manuals will be an awesome help!
I’ll try to spend some time with it over the weekend.
Again, thank you so much for all your help. I’ll let you guys know how it works out.
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
2000 CHEVROLET SILVERADO (A60736)
2000 CHEVROLET...
2006 International 7400 SFA Terex Hi-Ranger 6TC-65 65ft. Insulated Bucket Truck (A60352)
2006 International...
2018 CATERPILLAR 573D FELLER BUNCHER (A62129)
2018 CATERPILLAR...
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
