Are work lights "customization"?
   / Are work lights "customization"? #11
How much does the lightbar pull? Most I have seen/used use small gauge wires. What is stock alternator output?
The OP provided the Wattage for his light bar. Apply Ohms law from there.
The OP also provided his original and replacement alternator output ratings.
   / Are work lights "customization"? #12
I didn't see the 72 watts, I read it as 72 in led light bar...big difference in watts.
   / Are work lights "customization"? #13
Are lights customization? Well of course!
I added an accessory block bus bar for my front and rear lights. It allows me to expand for a few other accessories pretty easily as needed. I run inline fuses, and I put a fuse between the block and the battery as well 30 amp to start with but it will go up to 60 (I added this after the photos were taken so not visible). Only 25 bucks on amazon.
Those look handy!
I usually trust a good chassis ground for getting juice back to the battery.
   / Are work lights "customization"? #15
It would be interesting to check the amperage and see if the bar is really 72W. The watts and lumens advertised by some sellers are questionable.
I put the LED light bar on one of my variable voltage power supplies (Soronsen)
Set the voltage at about 13V.
This unit only displays up to 5 amps. The needle pegged, but the PS didn't trip out.
seems like 6 amps or so to me.
If I get issues, I'll put the amp clamp on it.
   / Are work lights "customization"? #19
Is "Fu**'in bright a proper metric?
It may be as meaningful as some of the sellers' claims:)
The light cast by LED's is interesting. Been using them for several years and they appear different when viewed from inside the cab vs. from outside the cab.
When inside looking out of the cab, they cast a nice bright light that doesn't seem like it would be very objectionable for someone observing them from a place that appears to be out of the illuminated area.
I've observed LED's while standing way beyond the illuminated area and the light was quite irritating to look towards. The distance from the lights and the angle they're viewed from don't do much to tame them.
   / Are work lights "customization"? #20
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
2014 FORD F-150 STX EXT CAB TRUCK (A60430)
2014 FORD F-150...
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
2000 Kiefer Bilt 20' Gooseneck Trailer (A59814)
2000 Kiefer Bilt...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
