Just another junk chainsaw
/ Just another junk chainsaw
No other reason besides I knew I could make it work. 🤦‍♂️😂
Started out 6” 1/4” mini micro set. Guess it thinks it’s cold already. 3” with spike. 4” without. 😋
5.3oz total b+c, after done.
What a clone and oem 2511 look like with bolt on cylinder with mag crank area to bolt into the plastic cases. Not clamshell style like some do.
These style can be base cut, squish cut etc for porting done right. For those into such.
Same way the pro built stihl 150T 151T does them too.
Friend showed us a clone tear down he was porting for US dealer.
/ Just another junk chainsaw #1,803
I saw that title on this thread and immediately thought "this must have Stihl equipment in it" but surprisingly I don't see much Stihl garbage in here.
You want some stihl. Plenty of stihl come in.
You wouldnt believe the folks that cant get their stihl's started.
Here was a worse case one I had to redo for a local.
another and the list grows ;)
I just laugh and point to a sign when the stihls come in. Guys so mad they cant get them started.
It has nothing to do with brand. He has to do with owners and the maintenance of OPE IMHO.
/ Just another junk chainsaw #1,808
I recall the 242 being around 15.5k. Then the OE 346 45cc 14.7k.
This new echo 501 I picked up says 13k-14k max in info. But I turned her down to a safe 12.8k if I recall right. I like saws to be hair fat enough to clear up in the cut. Not so fat they dont preform though.
I do recall Hydro having a 242 also, and 15,000+rpm Crazy. The Shop's Owner's Son PDI'd that one But I do remember him grabbing my Tach and asking if it went to 15Grand.
If you ever need a decomp plug for a newer echo. They will scare ya pricing one. 14 buck and if not buying from dealer add shipping too.
So for 2 bucks I made one. Just rednecking with hacksaw and grinder.
Guys with a lathe could do them really nice.
Use copper washer for crush ring. I didnt have one local so used brass for testing.
No you can not use husky, stihl, dolmar makita etc decomp plugs. One shown beside the one I made.
I'll post oem ones for echo too.
/ Just another junk chainsaw #1,810
View attachment 888458View attachment 888459View attachment 888460
With a cup of coffee these days that cost $7, $14 for a chainsaw part is cheap....
/ Just another junk chainsaw #1,811
Well, when every other brand I've ever had my hands on starts just fine and the Stihl won't.... When it's such a rampant issue that there are jokes and memes about Stihl all over the internet.....
It's not just their chainsaws. Their weed trimmers are just as bad. I have never in my life touched a piece of Stihl equipment that was worth pissing on if it was on fire.
A cheap Kobalt from Lowe's is even better than a Stihl.
/ Just another junk chainsaw #1,812
I'm down to one Stihl and won't be buying any more.
/ Just another junk chainsaw #1,815
People are baffled by carbs with no primer and how to start them.
It's really not that hard...
IMHO only fools pay that much for coffee. Let alone 14 for a decomp plug. 10mm short bolt :oops: 😂
Old saying a fool and his money are soon parted. :ROFLMAO:
Right over bench 1 of 3.
Inside a echo 2511 OEM muffler. Now you can see why they can not breath and need help big time.
Least no cat BS like in some of the others.
Friend had uncrimped his even after adding a gill exit before.
Stihl 034 super original owner. Just got to tell the story so others dont make same mistake he did.
Complaint was hard to start. Ask what all it did and he runs e-free so thats a good thing. He said he pulled the plug and cleaned and gap per manual.
I was like last time that saw was in pretty sure I put new plug in it so gap was right. I said show me where you gapped it on my gap tool as I was pulling plug. .050 he showed me on the tool. He says per his manual that came with saw. I showed him manual online it says .5mm
So then I go outside to start it. notta nothing. I'm like it have mix? Sure should have plenty. Open cap notta. So put some of my efree 40:1 vpracing in it and low behold she fires off. Shut off and tryed again from on started again.
Check the small things folks as owners. Double check your reading it right etc too.
So now I have left with 10 freaking chains to do for him grrrrrrr. I hate doing chains and it's repetition crap.
/ Just another junk chainsaw #1,819
I grin a ****te pile of chains and it is repetitious. I just turn on the local rock station to pass the time. Switched my ultrasonic cleaner over to a lye - water mixture to clean loops prior to grinding them. The lye removes all the pitch and crap on the teeth and keeps my CBN wheels much cleaner. I do have to oil them post grinding however. I've tried Simple Green and Berryman's and neither work as good as lye and water heated to about 120 degrees.
Just has another 50 or so dropped off this morning. I'm excited. Whole milk crate of chipper knives as well.
/ Just another junk chainsaw #1,820
View attachment 918654View attachment 918655View attachment 918656View attachment 918657
I don't 'uncrimp' them at all. I grind off the crimped over part with my large flat plate grinder, mod the muffler and then weld the 2 halves back together again. I either use a MIG or I TIG them if they are clean.
2015 CHEVROLET CAPRICE POLICE CAR (A66091)
2015 CHEVROLET...
2002 PETERBILT 330 VACUUM BOBTAIL (A67714)
2002 PETERBILT 330...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
6 1/4 INCH OD 90 DEGREE ELBOWS (A67714)
6 1/4 INCH OD 90...
Unused 2021 Unused Paladin MD60SC 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2021 Unused...
2018 INTERNATIONAL LT DAY CAB TRUCK TRACTOR (A69167)
2018 INTERNATIONAL...
