YM 1510D 4WD Front Axle and Bearing needed
/ YM 1510D 4WD Front Axle and Bearing needed
Very great response from all. Thanks for looking it this.
The axle without the bearing on is broken, I super glued it on just so I would not lose the piece. Thought about welding it on, as the bearing just needs to slide over that section.
I did get a quote for H&E Gear to make a new one, so the high end will $625, I am hoping someone will have a used axle, for maybe $150 to $250.
Again thanks for taking an interest in reviewing. Any and all comments are appreciated.
PearieEh
/ YM 1510D 4WD Front Axle and Bearing needed #13
/ YM 1510D 4WD Front Axle and Bearing needed #14
Oh yea the bearings are a simple fix at about $10 each from SKF 6304 deep.
On the YTOG, there was an outfit in Greece making splined shafts for us in 2 weeks time for over a year. We just haven't heard from the outfit in a while though. A complex splined shaft was about $80 if I recall.
Paouris Parts
Contact Enea
pick Yanmar on the main page, then search via p/n
BTW, do you need the bevel gear too?
re-manufactured on the left and the broken one on the right.
/ YM 1510D 4WD Front Axle and Bearing needed #15
What part of the world are you PearieEh In the US.? I'd use my My Elcheapo HF. stick welder on it and a grinding wheel. They make a small hand held the size of a battery Screw gun now. 100$ I really sux. at it but bet it would be pretty easy to do. I have shortened a PTO. Dr. shaft with the H.Frieght and I can hardly hold a welding rod. Bet it would work. Super glue the piece in place.(y) Your not going to break it Esp. knowing you have a problem and no loader! Had to remove a 10" section of a Yanmar Tiller. Last Tiller Fredricks had at the time and the PTO. Shaft was to long for my tractor. We had to go to one of the back warehouses and dig it out!! They sent the correct one to me in a couple. One of the Yanmar members may still have it. Pay the shipping and he was welcome to it!!
BTW, you picked out one great bearing based on the bearing standards and material. I would consider you an engineer.
Paouris Parts
Contact Enea
This is a great lead, but I don’t know any Greek. I will take a look at the YTOG site and see if I can find any references. I did go to the link for the parts website, but it is all Greek to me. - Thanks
Thanks for the tiller offer, I already have two. I live on the west coast of the USA, in a mountainous area. The tractor was in my back yard and I thought I would needed the 4WD to get it out, as my access road is about 30 degree angle. However, I had a chipper on the three point hitch and was able to back it up with only 2WD. Thank you
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
2003 POLAR TANK (A60736)
2003 POLAR TANK...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
Giyi DHC Mini Quick Attach Forks (A60463)
Giyi DHC Mini...
2020 John Deere 6120M (A60462)
2020 John Deere...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
