Thanks
@Molalla1
Mr. Matt, 2 questions:
Interested in how you get the grass cleaned up. You mentioned the landplane...I use it fairly often on my drive, but find it does not get the edge grass fully removed.
1. Can you explain your process for clearing the grass/weeds?
Next question: The flyer mentions "...as low as 3 cents per SF..."
2. Is that your normal rate for the type of work you provided in the most recent set of photos? (You're refresh is crisp and cheaper than simply adding more gravel based on my quick math!)
@BackRoad
Good questions: I do get similar questions on the other forums I'm on.
Try setting up the landplane where the cutting edge (if you have adjustment) is ~3/8" below the skid shoes, extend the top link to give the back cutting edge a more aggressive attack angle and depth. The front cutting edge may not perform any work, and that's ok. If you have scarifiers, drop them around 1" below the skid shoes if the driveway is compacted with deep roots before using the cutting edge. If you find the landplane is riding on top of the vegetation rather then biting or bouncing, add weight to each side plate.
In some circumstances - but not all - I'll use the tine rake to push/pull and separate the vegetation after it has been lifted. I know I'm not going to get all of the vegetation filtered out, but I also don't want to smother roots under the agitated gravel. I always recommend a spray routine with customers along the edge of the driveway to slow down the regrowth, and always educate mother nature does what she wants. This is only temporary and requires maintenance.
If there is excessive gravel in an area that I can relocate along the edges of the driveway, I'll relocate using the box blade to create the crisp lines with added gravel.
The 3 cents per SF (CDN) is an estimate if the driveway just needs to be tumbled with a few pot holes to fix and crowned. When there is vegetation over growth, the estimator does factor in raking and bucket time. Being a subcontractor, I charge by Time which includes loading/unloading and drive time. I'll submit my invoice with a time evaluation which helps the estimator retune their quotes. If the customer does consider top dressing with fresh stone - I always recommend performing a refresh, regrade and vegetation removal regardless. It's up to them if they want to top dress after this first step. Sometimes they do, sometimes they are happy with the refresh only.
Here's my time sheet invoice details on a job I had posted a few pages back. This helps retune the quoting process with justifiable activities. It also shows the customer the steps I took to perform the results if they need to see these details.
The Estimator uses Google Earth to support visual quoting with the customer and creates a job assessment with pictures for me to review. There is a tool to measure sqft so it may be calculated. In the overhead map example below, This job required a driveway refresh, soil top dressing, thatch, seeding, rolling and aeration.
The first job usually takes the longest, but when the job becomes a repeat - the first job I had done builds efficiency on the second, third, fourth...
My main focus is producing results in the most efficient time I can using the best tools for the job.
