Excavator, swap pilot lines
/ Excavator, swap pilot lines #1
Cord
Richfield, Wi
Resident Architect
I have a Komatsu PC75 excavator and I want to change the controls from ISO to SAE (backhoe). This is a pilot-operated machine, so this should be easily done at the valve stack. The question is how can I figure out which lines I need to swap? This machine has 9 spool sections so the valve stack is almost 2' high. Any suggestions would be appreciated.
/ Excavator, swap pilot lines #2
If you can get an accurate hydraulic schematic it should identify which valve section controls each function.
If no schematic then you are going to have to make your own by following hoses from joystick to valve sections and hoses from valve sections to function they operate.
Then hope the pilot hoses are long enough to allow you to move them.
/ Excavator, swap pilot lines #3
I’m m surprised it doesn’t have a change over valve.
/ Excavator, swap pilot lines #4
I agree. Surely it has to have a pattern change valve. Specially a machine this size.
Best I can tell, it does not. I was planning to add one.
Unused 2024 Land Pride PFL3048 48in. Forks and Frame Skid Steer Attachment (A66734)
Unused 2024 Land...
2012 BRENNER TANK PUP TRAILER (A67714)
2012 BRENNER TANK...
2020 CATERPILLAR 289D3 SKID STEER (A65056)
2020 CATERPILLAR...
2020 GMC AT4 CREW CAB TRUCK (A64280)
2020 GMC AT4 CREW...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2015 CHEVROLET SILVERADO 2500HD (A67714)
2015 CHEVROLET...
