Excavator, swap pilot lines
   / Excavator, swap pilot lines #1
Cord
Richfield, Wi
Resident Architect
I have a Komatsu PC75 excavator and I want to change the controls from ISO to SAE (backhoe). This is a pilot-operated machine, so this should be easily done at the valve stack. The question is how can I figure out which lines I need to swap? This machine has 9 spool sections so the valve stack is almost 2' high. Any suggestions would be appreciated.
   / Excavator, swap pilot lines #2
If you can get an accurate hydraulic schematic it should identify which valve section controls each function.
If no schematic then you are going to have to make your own by following hoses from joystick to valve sections and hoses from valve sections to function they operate.
Then hope the pilot hoses are long enough to allow you to move them.
   / Excavator, swap pilot lines #3
I’m m surprised it doesn’t have a change over valve.
   / Excavator, swap pilot lines #4
I agree. Surely it has to have a pattern change valve. Specially a machine this size.
Best I can tell, it does not. I was planning to add one.
2011 Ford E-350 Passenger Van (A53422)
2011 Ford E-350...
2008 Ford F-350 Pickup Truck (A55852)
2008 Ford F-350...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
