Excavator, swap pilot lines
   / Excavator, swap pilot lines #1
Cord
Richfield, Wi
Resident Architect
I have a Komatsu PC75 excavator and I want to change the controls from ISO to SAE (backhoe). This is a pilot-operated machine, so this should be easily done at the valve stack. The question is how can I figure out which lines I need to swap? This machine has 9 spool sections so the valve stack is almost 2' high. Any suggestions would be appreciated.
   / Excavator, swap pilot lines #2
If you can get an accurate hydraulic schematic it should identify which valve section controls each function.
If no schematic then you are going to have to make your own by following hoses from joystick to valve sections and hoses from valve sections to function they operate.
Then hope the pilot hoses are long enough to allow you to move them.
   / Excavator, swap pilot lines #3
I’m m surprised it doesn’t have a change over valve.
   / Excavator, swap pilot lines #4
I agree. Surely it has to have a pattern change valve. Specially a machine this size.
Best I can tell, it does not. I was planning to add one.
2013 FORD F-650 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 FORD F-650...
John Deere XUV620i (A50121)
John Deere XUV620i...
2018 JLG 1932R 19ft Electric Scissor Lift (A50322)
2018 JLG 1932R...
2008 Ford E-350 Versalift Vantel29N 29ft Bucket Van (A50323)
2008 Ford E-350...
3pt Fertilizer Spreader (A50120)
3pt Fertilizer...
PT Twin Drum Aerator (A50121)
PT Twin Drum...
