Rollover paranoia
/ Rollover paranoia #41
The Compact tractors are certainly more prone to this. They're lighter and have a higher COG. The Utility class is a different animal. More cast iron, lower COG, wider stance, PLUS the ability to turn the wheels around to widen the stance even more. It’s amazing what the highway mowing crews can do. Those tractors can seemingly climb mountains. My Compact, on the other hand, makes me nervous on the slightest of inclines.
/ Rollover paranoia #44
Those duals look like an interesting solution. And adding a foot or so more width from the center line surely would help quite a bit.
/ Rollover paranoia #45
I had a “B” series Kubota with a cab and found it very “tippy” as the weight is high and the wheelbase narrow. That was years ago and I moved up to a Grand L cabbed as the rear wheel base was almost 13” wider and thus the stability was much better . I’m now back to an open BX which works fine for my current needs .
/ Rollover paranoia #46
I got my first set of bi focal glasses, promptly tried to kill myself and the tractor. Working on rocky slopes and having the glasses change the location of the rocks and holes depending where you look down or out was a no go for me. Threw those glasses out that day and got a set of reading glasses.
My eyesight is way too bad to be able to function without glasses. Had contacts for many years but worsening astigmatism put the end to that. Seems every time I get a new prescription it takes me a week or so to get used to the way they're focused, though not so bad as to affect driving or tractor operation.
/ Rollover paranoia #47
This post is not to criticize the safety minded out there amongst you. Far from it, as I'm a lucky guy that rolled his tractor and survived it four years ago. My issue is wondering whether the "respect" that the incident instilled in me is proportional to the actual risk. My Kubota B3030 was the first and only tractor I've bought. Total noob guy. I was backing while moving dirt, hit an unexpected mound of dirt and rolled. The built in ROP of the cab protected me, and the door glass contained me and prevented entrapment or limb loss. My first thought laying there in the shattered glass was turning the motor off (fire), then getting out. Once I was standing outside looking at the dead tractor carcass, I wondered whether any of my neighbors were out and had seen me due to the potential embarrassment. I was all alone. Then it dawned on me that I had no cell phone, my wife was away, and had I been trapped it would have been about a 5 hour wait for her to find me. Then the fear set in. Totally preventable. I think the root causes were ignorance of both proper technique and the risks, rushing, and overconfidence. I happened to have an excavator on site, so I just chained the Kubota and flipped it upright. To my surprise there was absolutely zero damage besides the shattered door glass.
To my point- now I'm so nervous on most of my almost exclusively non-flat property that I'm hesitant to use the tractor for many things. I think remember the spec on it saying ok up to 12 or 15 degrees, but the worst slope anywhere I'd encounter is 11-12 degrees and even that gets me really anxious. I think the spec is for a bare tractor, not one with a FEL, belly mower, etc. so it doesn't help me feel any more confident. I tried leaving the belly mower installed to lower the CG but it was interfering enough that I opted to take it off. Not looking for a how-to or strategies for transiting hills, counterweighting, FEL tactics, etc. (Now) I've watched all those videos, which is why I admitted my ignorance as a factor in my accident.
Did I buy the wrong tractor? (kind of a narrow front axle) Am I unreasonably cautious? Is there such a thing? I considered getting an alarm/inclinometer to at least let me know when I'm reaching the nominal limits, kind of as a training aid to better know when nervousness is called for. It's almost like a fear of flying scenario situation. so, alarm or therapy? That's the Mrs., not me.
/ Rollover paranoia #48
The exact thing happened to me a few years ago. I have been running tractors for most of my 67 years and never had any issues. On a previous load some dirt dropped out of the loader so on the next load ,backing up I hit the small pile. That was it the tractor rolled on its side,no belt I leaped out and luckily made it. Lesson learned, belt on keep the load as low as possible.
/ Rollover paranoia #49
/ Rollover paranoia #52
Some men have good reason to fear being crushed in a rollover incident, especially while they sleep!
If I'd rolled my tractor and lived to tell the tale, I think my avatar would at least feature an upside down tractor. :D Just sayin'...
/ Rollover paranoia #53
Saw a tractor rolled over driving into town yesterday. Looked like an Oliver w loader and brushog on the back. Completely upsidedown not just tipped on its side. No ROP.
/ Rollover paranoia #57
I bought the combo tilt/incline meter from here.
And my pucker factor is at 10 degrees.
I will take more time to approach a task differently, if current position reaches this point and see no return back to zero degrees.
Thank God you lived to see another day.
And appreciate sharing your experience with the community.
As this incident can be replaced with any name out here.
I had the same feeling when my ZX10 slid out from underneath me. Sandy crowned road.
The raw hamburger meat of my hip at the hospital was a sight I will never forget.
My CO didn't chew me out but all of the staff had fun for a week as I limped around the motor pool.
After that, I kept sweeping the road for all liquids and debris that could get me again.
But the pucker factor stayed with me a long time. And that was a good thing....
Thanks for sharing!
/ Rollover paranoia #58
I've decided that it doesn't matter how many times I mow around my pond, I'm always going to be uncomfortable with the side angle in certain places. The only solution that I can think of is widening my tires. It's been raining all week, and too muddy to mess around jacking up the tractor and moving tires around, but once it's dry, I'm going to do that before mowing around the pond again!!!
/ Rollover paranoia #59
Would it be practical to just eliminate the need to mow around the pond? I know Glyphosphate is no friend to aquatic species, but would it be possible to redo the skirt in river rock and somehow eliminate the grass that grows there?
/ Rollover paranoia #60
Mowing looks really good when it's done, and I've been doing it for years. I'm just not getting used to the angle, or the fear that it's going to roll on me. I think widening the tires will make it more stable, and hopefully, less uncomfortable
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
2008 Big John 42' Log Trailer OFFSITE (A62613)
2008 Big John 42'...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2016 - Tier 4 Interim (A63689)
Kubota...
2003 Toyota Tundra Extra Cab Pickup (A62613)
2003 Toyota Tundra...
2017 Ford F-150 XL (A64127)
2017 Ford F-150 XL...
