CT 235 will not go into 4x4(front wheel assist)
   / CT 235 will not go into 4x4(front wheel assist) #1
Arpad
Bobcat CT235
After some maintenance being performed (rear wheel/hub reseal and new couplers), I now can’t get the front wheels into the 4x4 mode. Looking at the MX service manual, the selector arm is fairly simple looking and doesn’t appear to complicated to access.
The 4x4 mode did work after the above MX for a job I did, but wouldn’t budge the next day. The tractor is functional in 2x4 mode.
The arm feels like it is jammed in a position that it’s not supposed to be. Looks like Hyd fluid needs to be drained (again!), Roll pins removed and access plate removed to see what’s going on.
Any experience out there on this issue?
Disregard all. After some gentle persuasion with a 2# framing hammer, she be working per OEM.
   / CT 235 will not go into 4x4(front wheel assist) #3
I have always heard just get a bigger hammer. :D
   / CT 235 will not go into 4x4(front wheel assist) #4
That works :)
I always have trouble getting my Kioti *out* of 4wd until the next day after it cools down, when it pops right out easy as pie.
CATERPILLAR 420F2 IT BACKHOE (A60429)
CATERPILLAR 420F2...
2022 Can-Am Defender XT HD10 (A59814)
2022 Can-Am...
iDrive TDS-2010H...
207274 (A52708)
207274 (A52708)
WATER TRAILER (A58214)
2005 Peterbilt 357 T/A A-Frame Gin Pole Truck (A60460)
2005 Peterbilt 357...
