rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,755
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
After a small amount of flow is diverted to the power steering, all the remaining flow goes to a series of contol valve assemblies. Each control valve assembly from the FEL control onward - even if it is an assembly with only a single control valve like the 3pt control - feeds pressure out of its power beyond port and sends the pressure to the IN port of the next control valve in the series.Thanks for this. Where is this sleeve? Is this on the manifold or on the control valve (#21 below), which requires disconnecting the lines and removing the manifold. And to complicate things, the parts diagrams do not have a breakdown of the control valve but the manual does. I am guessing that they replace the control valve entirely and not the valves n bits themselves.
Here is the parts diagram I was able to get. They don’t make it easy to copy/paste links.
And what would be my PB port? Would it be labeled?
Usually the FEL power beyond port has PB stamped or cast next to it.
The sleeve is within the body of the control valve. To find it, locate the PB port, undo the hydraulic hose going to that PB port..... and the sleeve is the next thing inside the port.
Sometimes it just slips out and sometimes it is threaded.
Since you said that you had worked on that valve, your PB sleeve might have slipped out and been lost. It's a common enough problem to be worth mentioning. Stick around TBN for awhile and at least once a year someone takes their control valve apart and loses their PB sleeve. When they do, the tractor HST, and steering, and FEL all work fine, but nothing else hydraulic works at all. No pressure. A stuck accessory solenoid will do the same thing.
rScotty
