Rear 3PH is not working - running into a wall
/ Rear 3PH is not working - running into a wall #31
That rust could possibly have migrated to the control valve causing a spool to stick.
Not sure if this question was asked but is this a sudden failure or has 3 point never worked?
I took apart the manifold components and control valve, it looked fine with no rust at all.
IDK, I have had it for only 2 months, but it sat for a few years before that. I got it from my neighbor who’s hubby passed away and it was not used since he passed. He used to use it but never saw the 3PH used or any rear implement.
/ Rear 3PH is not working - running into a wall #33
First built 2008, so less than 16 yrs old. Maybe had been in a flood?
Not flooded. They bought it new in 2010 and we are not near floods. Lived next to them since they got it. It’s just metal that oxidizes since it’s steel and some of the fluid probably broke down and/or got some water in it. It’s not an issue just showing what happens when something sits. And people like pics.
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A62129)
KNOW BEFORE YOU...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
KMC 3pt 11 Shank Ripper (A60462)
KMC 3pt 11 Shank...
HYDRAULIC AUXILIARY TRANSMISSION (A60736)
HYDRAULIC...
