Rookie tractor buyer neds advice
/ Rookie tractor buyer neds advice #31
If you are smoothing the land to plant something, it’s hard to beat the combination of a box blade and rototiller.
/ Rookie tractor buyer neds advice #32
OP, as you gain experience the 26hp tractor you are looking at will shrink on you. Look higher up the power scale, ie 35 - 50 hp. You did mention cropping of some sort is being looked at.
Loader : SSQA with 3rd service so you can use things like grapple and generally future proof the tractor. Retro fitting is expensive. NOTE when comparing the lift capasity, some are measured at the bucket pins, this gives a good LOOKING result, but is not real world accurate. Others will measure the capasity from about 1 ft in front of the bucket pins. This gives an honest real world lift capasity, BUT looks worse.
3 point hitch, recommend you get a quick hitch there as this will help keep you away from dust when chaging attatchments.
Rear hydraulic couplings: recommend you get minimum of 2, 3 is better (future proofing) ie 1 set for the hydraulic top link will leave 2 for what ever attchment is on the back.
Tractor, at your level of inexperience you will need a CLOSE dealer.
Gearbox: hydrostatic as this is the best option for your inexperience and you can put anyone else on it as well. Also 4X4.
Tyres" AG tyres(R1) not industrial (R4) tyres as these don't do very well in mud. (the standard tyre is R4 in the size of tractor you are looking at.)
Rims: Ag tyres usually have 2 piece rims which means you can widen the track for greater stability and saftey easily. R4 and turf tyres are usually 1 piece rims and can't be adjusted.
Try the tractor for size as the ergonomics are slightly diffferent for each. ESPECIALLY check that the seat at maximum upper travel does not ram you into the roof before it runs out of travel. If you don't have neck and spine problems ,then you soon will.
If you can get an air ride seat over mechanical spring seat.
NOTE: with a cab, get heat AND A/C as even in winter you can get to hot with all that glass. (I had a tractor with dead air con', it was called microwave for a reason. Cab temps were routinely at 100 - 110 F in summer.)
Lastly, we need more info on the soil type and intentions/ options to give more specific advice.
Some food for thought, good luck
Thanks for all this.
I am getting pros to come talk to me about the soil but not for a while. It's Georgia so I assume it's orange. Maybe I should get a Kioti or Kubodo so it wont show the dirt lol.
That testing will ultimately drive what I end up planting. It could be even if I don't need a tiller for planting, I would want it for smoothing those elevation changes.
/ Rookie tractor buyer neds advice #34
The number 1 repeated suggestion "buy from a local dealer" The dealer you purchase from can make your life miserable or he can be easy to work with. Unless you do all of your own maintenance you will need a good dealer. I've owned an old ford a new Kubota and a used Kubota and now a Massey subcompact. I think my Kubota's would be my favorite. One thing that just came up lately is those hydrostatic transmissions will not take the abuse a gear drive, I just had my Massy GC in for transmission failure. Something to think about.
/ Rookie tractor buyer neds advice #35
The "local dealership" doesn't always mean good. An older dealership is old for a reason. Ask about service. A lot of tractors have came on the market in the last 20 years. Like cars, some good, some not so good. Have you seen a used Yugo for sale lately? John deere, Massey, New Holland (Ford), Case (International Farmall) are the main stays. Kubota is a good new comer. Several new subcompact brands have come and gone. Their wares are like litter on the hiway. If you have one, better try to find a couple more for parts. Unless you are thinking "hobby farming", you won't be farming but just playing after work and week ends. Give some deep thought as where you want to be in 10 years.
/ Rookie tractor buyer neds advice #36
Situation: Have somewhat accidentally ended up with six acres to maintain. Was initially going to get a subcompact and rotary cutter, but have felt like I should try to redeem the land and not just stare at shorter weeds on it. The land is “flat” but there are a lot of bumps and small (3-4 foot) elevation changes that I will try to level out some. I have asthma and need a cab, but our needs seem modest for the six-acres property where we’re going to try to keep a smallish farm. We don’t know what crops we will plant - we are working with the UGA extension team to figure that out.
A subcompact tractor is the wrong one for this application. I say this having used a Kubuto BX tractor with a mid-mount mower. The small tires were the biggest problem for me. Low traction and a really rough ride even in "good" pasture land. The B2601 did MUCH BETTER!
Today, I run a Kubota branded 4' rotary (AKA brushog) and a Land Pride 6' 3-pt mounted finish mower. That finish mower is the cats meow for mowing the yard around the house. On the three point, it lets me get under trees with scuffing up my tractor and tackles my friends big yard in under half the time it takes him with his Kubota BX mower. My tractor is 26HP with Hydrostat so ~19.5HP on the PTO which matters with the rotary cutting I do. 4 foot wide means ~5HP per foot of mower which is a good number for me. I have tackled weeds taller than I am with ease. In heavy flood out weedy areas that have dried, I can still bog the tractor down with this 4' rotary mower running Low gear and creeping forward.
Any less HP/Ft of mower would mean I would have to hire out this cutting task.
I have really liked Kioti and a big dealer gave me a quote on a CK2620 shipped to me. I've looked at and come close to buying used DK models. My local LS dealer has given me what seems like a great quote on the brand-new LS 226. I saw one dealer in Oklahoma has what seems to be a great deal on the TYM 4215 which I'm considering. I have gotten an okay quote on a Bobcat 2535 from a brand new dealer local to me but the attraction there is he's so local and we've done other business before so I trust him. I've visited a couple of JD dealers but their cab models are basically double my quote for the LS. Of course, I like the new tractor warranty but I'd be fine with a used tractor that has a good track record.
Which dealers are close to you? That being said today, my sister had a Kioti DK and to be honest it was a good tractor but, operating it was pretty tough on whoever was in the drivers seat. The loader bucket controls were also substantially below par which made smooth bucket movements hard.
Kubota loaders are super smooth operators and I can lift and curl the bucket (both hydraulic 'channels') at the same time. So smooth and easy to control.
Today, to be honest I'd buy a TYM tractor. Lots of quality at a better price than other options. In fact, I am debating selling my Kubota L-4600 which has a huge fan base for a slightly bigger TYM cabbed tractor.
Massey Freguson also makes a really great tractor if you have a dealer within reasonable driving distance.
I feel like as a total rookie it could be smart to get something bigger and more stable than I need. I can pay cash or finance and am making that decision based on how big the cash discount is.
Don't buy one too big to fit your barn, yard, gates, driveway, etc. Don't buy a subcompact either. In a pre-emissions tractor, 50~65Hp is a great power range in a modern UTILITY tractor.
Budget is max around $40k out the door with my starter implements.
I'm not sure what the cabbed prices are today for TYM options with all the inflation but, would get a mid-size TYM with cab with money left over for implements.
Would also be interested in two supplemental questions:
- What are the no brainer early attachments besides some kind of cutter and a box blade to help with the grading?
- Is a flail mower worth the upgrade over a rotary cutter, or put another way under what conditions would you splurge on the flail mower.
I use a land plan a lot more than box blade. Land Planes are awesome for smoothing out a driveway!
Flails don't eject things that will break windows and dent passing cars like a rotary will.
/ Rookie tractor buyer neds advice #37
I really have been focused on 25hp machines due to price and avoiding the regen. 40hp machines have only come in play when there’s a great deal.
For example, the TYM 4215 is considerably less than the Kioti 2620.
Modern Regen tractors aren't that big of a deal today in NEW tractors generally. Sure, if all you do is mow your lawn, it will need to do a high speed burn to clear the catalyst system but that shouldn't be feared.
You can find new 40~70Hp tractors that don't regen or use DEF if that is important to you. High Pressure fuel systems help along with better new generation engines and essentially a catalytic converter.
/ Rookie tractor buyer neds advice #39
Hi. I’m new to tractors but am getting close to buying one. I am a total rookie.
I'm very grateful for any help.
DON'T BUY A KOREAN TRACTOR!!! THEY DON'T HONOR THEIR WARRANTY!!!!
2004 Bobcat S185 (A60462)
2004 Bobcat S185...
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
2013 Peterbilt 567 Truck T/A Wet Kit Day Cab Truck Tractor (A60352)
2013 Peterbilt 567...
2015 Caterpillar 430F 4x4 Extendahoe Loader Backhoe (A60352)
2015 Caterpillar...
2011 SHOP MANIFOLD TRAILER (A58214)
2011 SHOP MANIFOLD...
2 new 8'' Pallet fork extensions (A61567)
2 new 8'' Pallet...
