850 sqft. Addition to house - Rockin' and Rollin'
/ 850 sqft. Addition to house - Rockin' and Rollin' #21
Bet your heat index has been hovering around 100 doing this framing.
/ 850 sqft. Addition to house - Rockin' and Rollin' #22
Nice project, moving along quickly. Your doing a lot of the work yourself? I assume frost is a non issue there? The footings look shallow compared to what they would be here. Continued good luck!👍
Yessir! Most days. When you're out out working in it everyday and you take the necessary precautions it is manageable. But by the end of the week I am whooped.
Thank you! It is definitely going well. Up to this point I have done everything except lay the block.
Technically the bottom of the footing should be 12" deep and most of them are except one little spot that needs to get backfilled some, then it will be 12" deep.. But no, we do not have issues with frost. If the ground ever froze 12" deep here I would be really shocked. I have seen ice on standing water only a handful of times in 25 years of living here.
8ft. Fork Extensions (A59228)
8ft. Fork...
2025 30in. Forks and Frame Mini Skid Steer Attachment (A59228)
2025 30in. Forks...
2005 Chevrolet C4500 Altec Bucket Truck (A56858)
2005 Chevrolet...
207274 (A52708)
207274 (A52708)
SKIDDED FRAC TANK (A60736)
SKIDDED FRAC TANK...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
